    [Plugin] Components manager plugin
    156 Posts 15 Posters 52.7k Views 15 Watching
    • inteloideI Offline
      inteloide
      This is a plugin to manage components in your model
      This plugin could be useful for mechanical system designers and others, who use of a lot of components, and modify components separately from the complete model.
      http://img11.hostingpics.net/pics/835047Componentsmanager.png
      Filter window
      Main functions :
      • Tells you if your model components are up to date (compared with saved files).
      • Allow you to update (upload/save) all components in your model at same time
      • Add relative link (path) to your components (ex : “..\test.skp” instead of “c:\a\b\c\test.skp”) : This allows you to change model location without need to update all link when you want to upload a component.
      • Add possibility to manage revsion level of a component (files like "c:\toto rev 3.skp"). If a higher level is found, it compares/uploads it !
      Install :
      Just add it as an extension or unzip files in Plugins directory
      Tool access :
      • It adds a menu : Plugins/BGSketchup/Component manager
      • It detects also OS language and translates to yours (only English and French support by now, you can freely add a new language by adding it in loclization.rb file. In this case, please send the file ;o) )
      Interface explainations:
      On top : the list of components in your model.
      • Click on one element to see some information on it, at bottom of window.
      • Icons reflect component status :
        -> Blue : not linked to a file
        -> Green : up to date (file = component in model)
        -> Orange : broken link between file and model
        -> Red : not up to date (file <> component in model)
        -> Mauve : Group (added only if there is component inside)
        -> Red triangle in right bottom corner : sub-component(s) present
      Model modification implications :
      • It adds attribute to component with a relative link and modification date of the component
      • It adds observers to model entities to check if something changed.
      Known limitations :
      • It was tried on windows 7 with sketchup 8 Pro and 2013 with internet explorer 11.
      • For Mac users, it should work...or pending, pending full tests.
      • The list is not updating “in real time”. I guess it could slow down the system. Maybe adding an option could be relevant.
      Version history :
      1.14.8 :
      Optimized : Move JQuery folder in root BGSketchup folder, in order to reduce plugin size
      Optimized : Language names now appear fully in Options
      Optimized : Change javascript error message in more accurate details
      Optimized : Some coding correction, thanks to Aerilius
      1.14.7:
      Corrected : Wrap localization in module to avoid interferences
      Corrected : When clicking on a raw object in model, the auto-selection in the list didn't worked anymore (Thanks Ole to saw this bug)
      Corrected : Change one French translation
      Corrected : When openning a new model, the list was not refreshing. Now it will, only if window is shown.
      Optimized : Add Html function to catch errors in javascript (mainly for SU 2014, but also for Safari)
      Thank you for any feedback
      The help file
      Version 1.14.8
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
      • G Offline
        glro
        @inteloide said:
        Hello,
        I would like to propose you a free plugin which allows you to manage component. This plugin is for sure not 100% complete but do the job required. I would like you to test it and give me your feedback for improvements.
        http://img11.hostingpics.net/pics/306356Screenshot.jpg
        Main functions :
        • Tells you if your model components are up to date against saved files.
        Before trying it, i'd like to understand better
        It seems complicated to me
        Could you explain what a relative link is?
        As i understand the way components work in sketchup, if a sketchup model includes components, they are saved with the model file , so when you move it, you don't have to bother about relative links..
        so why would you have to update links?
          inteloide
          Hello,
          First, I just update the plugin with some bug corrections.
          Secondly, to answer your question :
          The main idea is to be able to update a model if component of the model changed, even if the model directory changed also.
          Take one example :
          I have one drawing saved in "c:\toto\final\test.skp"
          This drawing use one component I saved in "c:\toto\component.skp"
          For some reason I modifed the component, it's easy to update it in SU (just you don't know in SU if component changed or not)
          But if changed also the folder with model and component from "c:\toto" to "d:\tata" (for example I saved it on USB key or on network) ?
          With relative link, it doesn't matter : component is saved in "..\component.skp", so nothing to do with "c:\toto" or "d:\tata".
          The attempt of this plugins is to have a "Layout references manager" like, but also in relative link.
          I hope this is more clear for you, if not, please do not hesitate to reply 😄
            inteloide
            Just updated with followon corrections :
            Add automatic link between version in "about" prompt and the extension version
            Add french translation in extension description
            Improve component loading, in sub-routing in order to reduce file size
            Make messages with "'" characters, in HTML, works.
            Reduce icons size to 23*23 to fit in same window width, due to "options" added button
            Added options prompt, removed the option menu
            Correct relatif link function error in BGSketchup.rb
            Correct error while saving all definitions
              inteloide
              1.2 full version history :
              Version history :
              1.2: Added : New option to show or not groups without sub-components
              Added : Update progress shown in status bar
              Added : Options are saved in model
              Optimized : Delete the global variable for reverse list of definition (not used anymore)
              Optimized : Update automatically the list when changing options
              Corrected : Add EN translation for "Group without name" in liste
              Corrected : When component include groups that mustn't be shown, icons showed a sub-directory
              Corrected : Replace openpanel by savepanel when asking for saving path
              Thank you for your feedbacks.
              • G Offline
                glro
                @inteloide said:
                Hello,
                i downloaded the plugin, but i don't understand how to use it
                I have a model made of components, but the components manager window is empty, i don't understand how to use the icons below
                could you describe step by step how to use the plugin, with a simple, from the blank sketchup window?
                  inteloide
                  ok, I will try to make a little video (but not today).
                  Normally, when you open a model, the widow shoud not be empty. If it's the case, an error has occured. May I ask to run the ruby consol, open a model and send me the consol error (if there is...)
                  Also, I insist, for sure on Mac it should not work, as I don't know how Mac filesystem works. If required, I could spend more time on this, if a Mac user help to verify it works.
                  For the icons below, from right to left (you can have help with keeping mouse on icon):
                  -Update the list (you may try this if your Windows is empty)
                  -Select in Sketchup the component selected in the list
                  -Change component path to the file
                  -Save selected component
                  -Upload selected component from file
                  -Save all components
                  -Upload all components from files
                  -Options
                  -About
                  • G Offline
                    glro
                    i get this error message in the console ruby
                    Error: #<NameError: uninitialized constant BGSketchup_Composants::Initialise_les_observers>
                    C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:482:in `onOpenModel'
                    with another model:
                    C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:474
                      inteloide
                      Hello Glro,
                      I just put another version with the bug corrected.
                      Actually, I have shortcut on my computer to skp file, I don't use File/Open from sketchup, and, of course..., ther was a bug Inside the procedure when openning.
                      Please try and tells me if it's ok now.
                      • G Offline
                        glro
                        i downloaded v 1.3
                        i don't have error message when loading a model , but the window is still empty
                        if i clic on the further left button (update the list), i get this error message in the console ruby
                        Error: #<NoMethodError: undefined method entities' for #<Sketchup::ComponentInstance:0xde80050>> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:63:in liste_composants'
                        C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:44:in maj_liste' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:43:in each'
                        C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:43:in maj_liste' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:24:in demarrer'
                        C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:63:in `call'
                          inteloide
                          Hello Glro,
                          It looks like you ran the plugin in SU 2013, in which I didn't try.
                          But I tried it and correct the error you had. Please download new version 1.3.1, which now works on SU 2013.
                          Thank for keeping me in touch.
                          • G Offline
                            glro
                            @inteloide said:
                            Hello Glro,
                            I use SU 8
                            With the new version of your plugin, i get a list clicking on the further left button of your popup window
                            But when i clic ont he next button to the right, the elected components don't match with the name in the window
                            mismatch component
                            Tne component name selected should be KLC4, but it selects KEMB
                            The same with KLC1: selects KEMB
                            which happens to be in first position in your window...
                            I tried the other buttons, but since i don't understand what thaey stand for, i cannot say much
                            the 3rd from the right gives this error message:
                            Error: #<NoMethodError: undefined method entities' for #<Sketchup::ComponentInstance:0xc9888f0>> C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:332:in upload'
                            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:317:in recharger_definitions' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:316:in each'
                            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:316:in recharger_definitions' C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:28:in demarrer'
                            C:/Archivos de programa/Google/Google SketchUp 8/Plugins/BGSketchup/Composants/Rb/Composants_Main.rb:332:in `call'
                            • ElibjrE Offline
                              Elibjr
                              Hi Inteloide,
                              Wow this looks promising. It reminds me of TIG's Xref tool. I won't be able to try it for a couple days but for a person who uses "offsite" components because I tend to edit them separately, this is like the Xref tool on steroids. Thank you! EB.
                                inteloide
                                @elibjr said:
                                Hi Inteloide,
                                Thank you for these encouragements ! I hope it will works 100% soon.
                                Glro : I corrected bugs thank to your PM. Now it works ok on version 1.3.2.
                                ACTUALLY, EVERYBODY WHO DOWNLOADED V1.3.1 SHOULD DOWNLOAD V1.3.2, because bug was consequent : the selected element doesn't match the real element in some cases.
                                Glro, thank to your sample, I think that the best would be also to have the possibility to collapse all instances in the same list element to reduce the number of lines in the list.
                                Maybe something like :
                                (4) KPI3
                                (6) KPI4
                                instead of ahving 4 times KPI3 and 6 times KPI4.
                                => I try to add this function at same time than help file.
                                • G Offline
                                  glro
                                  .. I think that the best would be also to have the possibility to collapse all instances in the same list element to reduce the number of lines in the list.
                                  (4) KPI3
                                  (6) KPI4
                                  v1.3.2 works on my computer; the selected component matches the one selected in the window
                                  i tried the buttons, with a model made of components
                                  the 4th one from the left launches a popup window proposing to register the component again
                                  if i do so, its name turns to green in the window
                                  but i don't understand how useful it can be
                                  if i close this model and begin a new one from scratch, the component definitions remain in the window... i have to close it and open it again to refresh
                                  if i drag components into the sketchup window, their name in the component manager window are written in orange, no link is made...
                                  i don't understand; maybe the help document you prepare will be useful
                                  • JQLJ Offline
                                    JQL
                                    Inteloide,
                                    I've been wanting something like this forever. Even if I don't deal with mechanic enginnering the amount of components and xrefs I use is very hard to manage with native SU tools.
                                    I'll give it a spin immediately and tell you about it's usage and any bugs I find out.
                                    Thanks and best regards,
                                    EDIT: I noticed only 5 downloads this is not consistent with the usefulness of your plugin. Did you try publishing it in Sketchucation Plugin Store. There is a form for that and that can get you a whole lot more downloads...
                                    JQL
                                    www.casca.pt
                                    Visit us on facebook!
                                      inteloide
                                      Thank you JQL, that make me "boost".
                                      Two things :
                                      • I wanted to post officially the plugin when working 100% ok. Glro already help me on that even if I desesperate to explain how useful the plugin could be.
                                        -I cannot find where to post a plugin, I looked in the pluginstore but couldn't find easily... I'll ask SketchUcation team how to proceed.
                                      After some feedback and maybe 2-3 improvment I have in my mind and I will officially post it. Hope this will be done for end of week. 🎉
                                      In few seconds, I post the new version 1.4.0 with interesting updates :
                                      Added : Options are now saved in My Documents folder instead of Inside Model
                                      Added : Option to select automatically the instances in the model (yes by default)
                                      Added : Number of instances of components beside component definition name, ex : toto (*3), means 3 instances in the branch of the list
                                      Added : Plugin version in title for more traceability
                                      Added : Update list when openning an existing file or creating a new file
                                      Removed : Progress in Sketchup state bar (I will try in implement again later)
                                      Removed : Old code for sub-menu options
                                      Corrected : Error in observers for new model and open model
                                      Corrected : Components in root of the model were duplicated in the list : not anymore
                                      • Rich O BrienR Online
                                        I'll add you to the Plugin Author group tomorrow and get this listed in the PluginStore
                                        Thanks for sharing your plugin here
                                          inteloide
                                          ok thanks !
                                          Just post version 1.4.1, as Win32API.so file is required, for option saving.
                                          It didn't saw it as it was included on my computer with other plugin I have...
                                          • G Offline
                                            glro
                                            @inteloide said:
                                            ok thanks !
                                            version 1.4.1 lists components as you wrote
                                            here is a screen shot of my screen
                                            re load definition problem
                                            All components came previously from my components folder
                                            for the components written in green, I modified the definition path using the 3rd button from the left; that is why they are written in green
                                            I didn't do it for the components written in orange
                                            For this particular component written in orange, i tried to reload the existing definition, and failed...
                                            Why is it necessary to create manually a new definition, anyway, since the address of the component is known (shown at the bottom of the window)?
                                            Why is it that the plugin does not go directly to the adress of the component and check if it is up to date?
                                            Maybe i don't understand well the definition of "definition"...
                                            • 6
                                            • 7
                                            • 8
                                            • 6 / 8
