    Hyperlink in LayOut
    layout
    2 Posts 2 Posters 1.3k Views 2 Watching
    • JAWSnAZJ
      JAWSnAZ
      I have a question. Is it possible to add a hyperlink type feature to Lay-Out or as a PDF. I use an estimating software called OnCenter. In the "On-Screen Takeoff" portion of the software there is a feature that I absolutely love. I can draw a box around a detail and name it. It becomes a destination. Then I go back through the plans and install buttons on each of the detail number arrows. I use dual monitors. When I click on the detail marker on an elevation page a pop-up window opens with a close up of that detail. It make reading plans so much faster.
      https://lh6.googleusercontent.com/-gOOGyMwerpo/UsIUlbN3FtI/AAAAAAAABBs/lAL5O8oUK2E/w1598-h577-no/Goodwill+Details.jpg
      Windows 7 Pro 64
      i7-3770 3.4Ghz 32GB RAM
      GeForce GTX 650 Ti
      3dconnexion SpaceNavigator 3D Mouse
      Dual 27" Monitors
      My Site
      • RichardR
        Richard
        Mate you cant do it in LO - though it is a fairly easy task to set this up in your PDF after export using almost any PDF editor!
        BUILTBRAND.COM.AU
