    Is the ruby source for rectangle tool or similar available?
    2 Posts 2 Posters 326 Views 2 Watching
      bobdiya
      I've been reading up the ruby source of tools - Construction line, Sphere tool by Jim Foltz and rotate scale tool by thomthom. They have been very helpful in writing my tool.
      Also, I have been wondering if there exists a version of ruby source for rectangle tool. The source to this tool will help me figure a lot of things I want to achieve. I searched for it but in vain. Even an older version or something similar would be helpful.
        There are several 'rectangle' plugins available, like '3 point rectangle' ...
        My own 2Dtools includes a 'rectangle tool' making 4 edges - no face...
        The principal is very similar to the line-tool example, instead of picking 2 points, you pick 3.
        The 'box' tool also has a potential crib...
        Point 1 click = p1 the start of an edge
        Point 2 click = p2 the end of that edge
        A Vector - vec = p1.vector_to(p2)
        Point 3 click - poff - this defines the offset to the opposite side NOT a vertex.
        A Line - line = [poff, vec]
        Project p1 & p2 to line
        p3 = p2.project_to_line(line) p4 = p1.project_to_line(line)
        Now if you want a face:
        face = Sketchup.active_model.active_entities.add_face(p1, p2, p3, p4)
        The edges get automatically added.
        If you want just edges:
        edges = Sketchup.active_model.active_entities.add_edges(p1, p2, p3, p4, p1)
        Remember to close the loop by reusing the first point again at the end...
        ***To get the temporary graphics rubber-banding that is needed in 'draw'... use the initial 2 points as if it's the line-tool, and then after the stare increments... while waiting for the 'poff' click the mouse's cursor-position can be used for calculating the the dynamically changing projected points from those 2, to draw the four sides of the potential rectangle as the cursor moves...
