    Help needed with sin, cos & co...
    3 Posts 2 Posters 348 Views 2 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi there,
      so i stick in place with a math-problem:
      let us assume, i have
      two lines in a traingle defined with
      a1
      b1
      i can count the angle by
      @mainangle_l = Math;;atan(a1/b1).radians
      puts also gives me the right angle in the console (compared with the drawing = check)
      in the next step i have to calculate another triangle, same angle, but have values
      @mainangle_l
      c2
      BUT
      a2 = c2 * Math.sin(@mainangle_l))
      does not give me the right value for a2
      i tried different variations of the syntax, but no way to get it.
      obviously i define the Math-function in a wrong way. but in the api, i canot find examples.
      can anybody help fo rgeneral understanding of trigon. functions??
      thanx a lot!!!
      stan
        The atan only works for a right-angled triangle.
        Because all 3 angles always add up to 180 degrees then:
        a2 = 180.degrees - (Math::atan(a1/b1))
        The angle a2 is in radians
        a2.radians
        gives it in degrees...
        I think you are jumbling up radians and degrees [again] πŸ˜’
        You can use other 'Sine Rule' formulas to find relationships between the enclosed angles and their opposing sides etc, when there is NO right-angle in the three angles - like:
        a/sinA = b/sinB = c/sinC = d
        Where ' d' is the diameter of the enclosing circle that passes through the 3 vertices
        substitute the desired lengths and the real sine values for the angles [using radians/degrees appropriately]...
        Rearrange the formulas to get any value... e.g.
        a = sinA*b/sinB
        or
        A = asin(a*sinB/b)
        Note too that the triangle's area is found using a*b*sinC/2
        or similar permutations of the values...
          artmusicstudio
          hi tig,
          great , good formulas for further studies.
          my code works now, by the way.
          just to precise my informations:
          i understand, that "atan" only works for right-angled triangles (one angle = 90 degrees),
          but: is the sum of angles not 180 degrees in all triangles?
          so the criterium is the right angle, not the sum of 180 Β°, right ?
          "jumbling up radians and degrees [again]" _:)
          yes, i still sometimes mix it somehow, but i try to keep all calculaction in skp-origin
          and only to display in the console in degrees. seems to work now! _ πŸ˜„
          so thanx again, all your tips makes my learning much easier!
          btw.: when a beta of the ruby is done and i made my tests, do you think, you and maybe somebody else , too, could check it on his machine?
          i have lots of rubys in my sketchup, so the compatibility here is ok, but who knows...!!!
          thanx stan
