    Same Name Selection
    7 Posts 3 Posters 456 Views 3 Watching
    • pingpinkP Offline
      pingpink
      I want to select groups or components , and material faces by the same name for the purpose of swapping objects and colors in a whole set for the revision , but I don't know an appropriate method to do it.
      what should I do ?
      def select_object_by_name
        model=Sketchup.active_model
        ss=model.selection
        ss.each do |e|
        if e.is_a? Sketchup;;ComponentInstance || e.is_a? Sketchup;;Group
        model.active_entities.each{|e|ss.add e if e.typename == component.definition.name}
        model.active_entities.each{|e|ss.add e if e.typename == group.entities.parent}
      def select_material_by_name
        ss=model.selection
        ss.each do |e|
        if e.is_a? Sketchup;;Face
        model.active_entities.each{|e|ss.add e if e.typename == face.material}
        Some alternative ideas...
        def select_active_instances_of_same_definition()
          ants=model.active_entities
          ss=model.selection
          ss.grep(Sketchup;;ComponentInstance).each{|i|
            defn=i.definition
            ants.grep(Sketchup;;ComponentInstance).find_all{|e|
              e.definition==defn
            }.each{|e|
              ss.add(e)
        end#def
        def select_active_groups_with_same_name()
          ss=model.selection
          ss.grep(Sketchup;;Group).each{|g|
            next if (n=g.name).empty? ### ??
            ants.grep(Sketchup;;Group).each{|e|
              ss.add(e) if n==e.name
        end#def
        def select_active_faces_with_same_material()
          ss=model.selection
          ss.grep(Sketchup;;Face).each{|f|
            mat=f.material
            ants.grep(Sketchup;;Face).find_all{|e|
              e.material==mat
            }.each{|e|
              ss.add(e)
            break ### stops after first face in selection is processed
            ### add a leading # to process ALL selected faces
        end#def
        πŸ€“ [mod=:3szy45z5]EDITED: ss.add(e) fixed.[/mod:3szy45z5]
        • pingpinkP Offline
          pingpink
          I'm very grateful for your help , Professor TIG !
          I test codes and they works for selecting groups and components with the same name , but the same face material seems doesn't select. I don't know why.
          You are so nice !! πŸ˜„
                  ss=model.selection
                    mat=f.material
                      e.material==mat
                    }.each{|e|
                      ss.add(e)
            end#def
            Typo !
            ss.add
            should be
            ss.add**(e)**
            πŸ˜’
            • tt_suT Offline
              tt_su
              By the way - on the usage of typename: http://www.thomthom.net/thoughts/2011/12/never-ever-use-typename/
              • pingpinkP Offline
                pingpink
                β˜€
                Wow !
                Many thanks for the useful tool. I can revise model quickly.
                It works very very nice !!
                result picture
                • pingpinkP Offline
                  pingpink
                  Thanks tt_su ! , I'm going to read it !
