    Module variable with 'require' problem
    8 Posts 4 Posters 537 Views 4 Watching
    • inteloideI Offline
      inteloide
      Hello !
      I'm developping plugins that become bigger and bigger. Therefore, to make code more readable, I split it in different files, using function 'require'.
      I'm following Thomthom's golden rules πŸ˜‰ , by using module and then module variable.
      But when in file linked by 'require' I cannot access to module variable anymore !
      Here is a simplified sample to explain :
      Here is the first file (called 'A.rb'):
      [pre:1oz1zcpi]
      require 'sketchup.rb'
      module M
      	class A
      		def initialize
      			@@var="123"
      		def show
      			UI.messagebox(@@var)
      			change
      		require 'B.rb'
      	Mod=A.new
      end #module
      if !file_loaded?(__FILE__) then
      	m = UI.menu("Plugins").add_item("Test")  {M;;Mod.show  }
      file_loaded(__FILE__)
      [/pre:1oz1zcpi]
      And here is the second file ('B.rb'):
      def change
      	@@var="321"
      If you run the code, you will have 2 message boxes with '123'. As change has not been called.
      Now, just replace require 'B.rb' by the code of B.rb (='def change....') and it works ! You have two mesaage boxes, one with '123' the other '321'.
      Actually, @@var is not defined anymore in B.rb ?!
      Does anyone already face this problem ? Thank you for your help !
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
        Initially define the...
        @@var=nil
        in the module itself, NOT inside the classes or defs... and then in each class [outside of any defs] you add...
        include moduleName
        The @@var is then available to all methods in the module and within that module's class ?
        You cannot pass @@var between them otherwise...
          driven
          without tests...
          shouldn't you require 'B' before trying to use it? i.e. at the top, or before your show method...
          john
            inteloide
            Thank you TIG, it works !
            Driven, I didn't try your solution, but I want the B file to be part of the module, not outside.
            The full code with TIG's solution :
            module M
            	@@var=nil
            	class A
            		include M
            		def initialize
            			@@var="123"
            		def show
            			UI.messagebox( @@var)
            			change
            		require 'B.rb'
            	Mod=A.new
            end #module
            include M
            def change
            	@@var="321"
              module M
                 @@var=nil
                 class M;;A
                   include M
              and
              module M
                 @@var=nil
                 class M;;B
                   include M
              • Dan RathbunD Offline
                Dan Rathbun
                @inteloide said:
                And here is the second file ('B.rb'):[/b]
                include M
                > def change
                > 	@@var="321"
                > end
                Do not do this (above.)
                You are including module M into Object, which means you are including module M in EVERYTHING!
                file "a.rb"
                module M
                  module I
                    @@var = nil
                    def change(val="321")
                      @@var = val
                  end # module I
                end # module M
                file "b.rb"
                module M
                  require("a.rb")
                  class A
                    include M;;I
                  end # class
                end # module M
                πŸ’­
                I'm not here much anymore.
                  inteloide
                  Hi !
                  Thank you Dan for your comment, you're right M was include everywhere.
                  I have seen in your code that you include A.rb in B.rb, I wanted the opposite, so I tried, the code below
                  For 'A.rb' :
                  module M
                  	class A
                  		require 'B.rb'
                  		include M;;I
                  		def initialize
                  			@@var="123"
                  		def show
                  			change
                  	Mod=A.new
                  end #module M
                  For 'B.rb' :
                  module M
                  	module I
                  		@@var=nil
                  		def change
                  			@@var="321"
                  	end #module I
                  end #Module M
                  Now, the problem is that @@var must be define in B.rb : what about if I need to create a third file which require @@var ? I must declare again the same variable !
                  Any solution ? (Because in my plugins, there are a lot of variables used in a lot of sub-programs...
                  Any help would be apreciated !
                    Dan Rathbun
                    NO.. the @@var is a module variable. It is SHARED by ALL classes and modules that include the mixin module M::I
                    If you change @@var value from an instance of class M::A, all other instances will see the change. Also any modules that included the M::I mixin will share the @@var. (It is a proxy lookup INTO the mixin library module M::I.)
                    Files are NOT included (that is a Python feature.) IN Ruby modules are included. A file can define multiple modules.
                    If you want each class instance or sub-module to use it's OWN variables, the use instance vars, ... @var (only a single @ before the variable name.)
                    This is all basic Ruby, explained in the "Pick-Axe" Book.
                    πŸ’­
