    Fredo scale and unique components
    extensions
    3 Posts 3 Posters 2.0k Views 3 Watching
    • N Offline
      Nicholas111
      Hello Sketchucation,
      I have been using the fredo scale tool recently however have encountered a problem.
      The problem is that when the group object is scaled it is creating components which should not be unique unique. The components can be renamed afterwards however I would like to know if there are any settings/preferences/work arounds which would enable me to continue to use this handy tool whilst keeping components non-unique & linked.
      Best Wishes,
      Nick.
      • BoxB Offline
        If you use Fredoscale on closed or multiple components it will make them unique, but if you use it on one component open for editing it will edit all of them and not make them unique.
          charlezzz
          yeah I still have the same probleme... it creats multiples unique component when you scale a group with components inside. Any solution ?
