    New TT Library
    6 Posts 4 Posters 625 Views 4 Watching
    • micioneM
      micione
      I have a problem to install in SU8.
      How to solve?
      • mitcorbM
        mitcorb
        Hi:
        I did a search on "permissions" in the search box at the very top of the page. I got this: http://sketchucation.com/forums/searchgoogle.php?keyword=permissions
        I did not read through but the text at each item may suggest that there are solutions. This is a Windows administrative rights issue. You must give yourself full permission to read write and alter at every level.
        I hope this may help you.
        • micioneM
          micione
          mitcorb,
          It seems to me to be right,
          but does not work anyway.
          • V
            victor hugo
            I've installed the new TT_lib v2.91 attached error after erasing old one and I get the attached error..
            Anyone else had this error?
            Thanks.
            • G
              g_wilson
              I also have a problem with this. I should elaborate - installed directly from Store - did not delete any previous - checked directory - TT_Lib2.rb dated 11/18/2013 and TT_Lib2 Folder dated 11/20/2013. Also - from TT_Lib2.rb ==> PLUGIN_VERSION = '2.9.1'.freeze
              • G
                g_wilson
                Added Info: I just renamed both folder and rb to get them out of the picture and re-installed TT_Lib 2.9.1 from Store again - same result. And - yes - I exit SU8 and then restart.
