    Math-problem
    8 Posts 3 Posters 513 Views 3 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi,
      i cannot find my mistake
      with
      @run = 30
      @lwidthplus = 20
      the formula
      angle2 = (Math.tan(@lwidthplus/@run))*180/Math::PI
      does not give me the right angle.
      as far , as i understand
      (Math.tan(@lwidthplus/@run)) gives me the RAD
      and
      *180/Math::PI should give me the degrees
      any idea, where my mistake is?
      thanx stan
        The numeric methods:
        .degrees
        .radians
        will do the conversions for you.
        No need for PI and convolutions... πŸ˜’
        AND use floats for length, angles etc, rather than integers [which are OK for 'counting' but not any maths]:
        30.0 not 30
        180.0 not 180
        etc
        Because
        20 / 30 >> 0
        whereas
        20.0 / 30.0 >> 0.666666666666667
        etc
        • icehuliI Offline
          icehuli
          try
          @run = 30.0
          @lwidthplus = 20.0
          p.s. are you sure that you are using Math.tan instead of Math.atan ?
            artmusicstudio
            hi tig & icehuli,
            @tig: yes, the numbers come from another modules and should be float (with direct input "45.degrees" in tr for angle2 the object is turned by 45 degr.)
            in the code below i tried the 'simple way', not clear to me, why it still does not work
            @icehuli
            see the code, the function should be the right one
                    new_line = @entities2.add_line pfm1, pfm2 # gives vertical line
            	@vector = new_line.line[1]
            	point = [0,0,0]
            	angle = (Math.tan(@lwidthplus/@run)) # x,y come from another module
            	angle2 = angle.degrees # trying to become degrees
                    puts "@lwidthplus",@lwidthplus #gives >> 7.8740157480315 (equiv. to 20)
            	puts "@run",@run #gives >> 11.8110236220472(equiv. to 30)
                    puts angle  #gives >> 1.5574077246549, should be 0,6666666 ( = 20/30 >> about 34 degr.)
            	puts angle2  #gives >> 0.0271818925912213
            	tr = Geom;;Transformation.rotation(point,@vector,angle2) # turnes somehow
            	group.entities.transform_entities(tr, group.entities.to_a)
            	@m_pf_l = group.to_component
            	defn = @m_pf_l.definition
            	defn.name = "@m_pf_l"
            it must be something very simple....but i cannot see it!
            stan
              You confuse methods...
              angle.degrees makes the number into radians - useful of you want to input user-friendly values like 45.degrees >> 0.785398163397449 radians is much more intuitive than Math::PI/4.0 >> 0.785398163397448 radians etc
              Then
              angle.radians makes the number into degrees - useful if you have calculated an angle in radians but want it displaying in a user-friendly degree format... 0.785398163397448.radians >> 45.0 degrees
                artmusicstudio
                hi tig, ok. i will make tests and learn.
                but anyway:
                why does
                angle = Math.tan(20.0/30.0)
                give (by puts angle)
                0.786842889472977
                instead of
                0.66666666 (normal tangens)
                and if 0.786842889472977 = 20/30 in radians,
                why does angle.radians then not give 33.69 degrees?
                sorry, i am confused, i seem to misunderstand someting totaly...
                stan
                • icehuliI Offline
                  icehuli
                  if 20.0 and 30.0 are the edges, 20.0/30.0 is already the tangent value. You should use Math.atan to get the angel out of it.
                  so in short:
                  angel = (Math.atan(@lwidthplus/@run)).radians
                    artmusicstudio
                    hi icehuli,
                    that's it! of course, i already had the tanges, so......sometimes it's so clear afterwards...
                    thanx a lot, the method works now!
                    new_line = @entities2.add_line @pfm1, @pfm2
                    point = [0,0,0]
                    angle = (Math.atan(var4/@run)).radians
                    angle = 360 - (Math.atan(var4/@run)).radians  if var5 == "right"
                    tr = Geom;;Transformation.rotation(point,@vector,angle.degrees)
                    @group.entities.transform_entities(tr, @group.entities.to_a)
                    stan
