    Plugin for adding laser cutter tabs
    3 Posts 2 Posters 365 Views 2 Watching
      jonbowen234
      I spend a lot of time making tabs on stuff so I can fit them together after they have been laser cut. It's rather annoying. I've spend to some time looking for plugins but I have not been able to find one that works. I did find Slots 4 Tabs but it doesn't seem to work in the new version and appears to be rather old. I'd like to get something that automatically makes the tabs but I can work with something that works like Slots for Tabs or even just one that allows me to intersect components without switching to Pro.
      Any ideas?
        Have you tried the Flattery plugin?
        BTW, you don't need the pro version to make intersections.
          jonbowen234
          I have flattery but the tab function doesn't work on 3D solids. I like to rough in my pieces and then add the tabs but flattery creates more work in the process and I can't specify lengths/squareness. It just takes the entire line segment and adds a tab. I need something to add like 5 tabs equal distance from each other and equal size along this parts edge.
          Also I need to intersect components not faces. Intersecting faces is a nightmare to clean up and not worth the time. I want to overlap two components and then intersect them without ever breaking the components up. Then I could make keys with the tab pattern in them and create the first piece then mate it to the second and intersect again.
          Slot 4 Tab would be really close to what I need but it's not working and the thread has not been updated since 2010.
