    1001 Bit Tools Crashing
    extensions
    12 Posts 7 Posters 3.9k Views 7 Watching
    • C
      CNCA
      Has anyone else found that the 1001 Bit Tools "Extend Edge to Edge or Face" tool crashes the program whenever it is used? I am using Pro on a Win 7 machine.
        Try to use it alone inside a folder "Plugins" for see if there is no problem betwween other installed plugins !
        • C
          CNCA
          Not quite sure how to do that.
          • K
            KrisM
            Yes, I have the same problem. I have emailed the author and he has been unable to track down the problem.
            Kris 😞
            • Bob JamesB
              Bob James
              I had the same problem, but upgraded to the newest version and it works fine
                Normally
                Just renamme the original "Plugins" folder in any name you want
                Create a new folder named Plugins
                Copy past inside all 1001bit files from the original
                When your test is finished
                Kill this new Plugin folder ans rename the temporay folder in "Plugins"
                That's all πŸ˜„
                • icehuliI
                  icehuli
                  Normally
                  That's all πŸ˜„
                  I tried this and it again crashed....
                  Windows 8, Sketchup 2013 free
                  • G
                    gohch
                    hi guys,
                    I have been trying to catch the crashing bug for 1001bit in SU2013, the odd thing is, for some pcs, it crashes a few times and then seems to solve itself without me doing anything.
                    I tried to run 1001bit inside SU2014, Windows8.1;
                    it crashes initially, after i changed SU2014 to run under Win7 compatibility mode, it no longer crashes.
                    Thought I update everyone on this.
                    Cheers!
                    GohCH
                    • G
                      gohch
                      ok, this is really odd, i ran SU2014 in Win7 and the crash occurred,
                      and then i ran SU2014 on Win7 again with compatibility mode set to XP(service pack 3) and no more crashes.
                      Ran SU2014 on Win7 with compatibility set to Vista SP2 no crashes.
                      So, in Win8 i have to run as compatibility for Win7
                      and in Win7 i have to run as compatibility for XP or Vista
                      odd...
                      • G
                        gohch
                        Managed to catch the BUG!!!
                        The bugs in the tools that caused the crashes:
                        "extend to edge or face"
                        "information between 2 points"
                        have been fixed in the latest rbz file:
                        http://www.1001bit.com/pro/download/1001bit_pro(v2.2).rbz
                        I have tested the other tools to work fine in SU2014,
                        if anyone has any issue, please let me know and i will look into it.
                        Thanks and cheers!
                        Goh
                        • K
                          KrisM
                          Goh,
                          Thank you for your perseverance in tracking this down. Some bugs are elusive.
                          KrisM
                          • H
                            hinangel
                            Hi there,
                            I am having problem with 100 Bit Tools Pro..
                            All 4 of the array tools crashes every i use it by selecting the line or point.
                            other than that, all tools seem working...
                            I am on Sketchup 2013 Pro with Window 7.
                            Please help!...
