    Split model
    4 Posts 2 Posters 442 Views 2 Watching
      miikka1978
      I haven't been actively following plugin forum for a while so I would like to check if there is certain plugin available. Do you have any idea how to split or cut my model into separate pieces? I have a model which has many (6) geometry levels on top of each other, see picture. I use this model for splatmaps by exporting flat top view image at the highest resolution. Now I would need to split the model into 4 same size pieces in order to be able to export it in higher resolution.
      Is there some plugin that would enable me to divide this model into 4 same size pieces? I am still making changes into the model and I will most probably need to do this multiple times in the project. Therefore I would need to have some easy/automatic way to do this.
      http://i.imgur.com/BAnUnr8.jpg
      http://i.imgur.com/pA9mwo0.jpg
      • KrisidiousK Offline
        Krisidious
        Slicer... or Slice.
        By: Kristoff Rand
          Krisidious
          Oh and Zorro2
          By: Kristoff Rand
            miikka1978
            Thanks for suggestion I had totally forgot Zorro! The problem is that it seems to get me bug splat quite often. Maybe that is because my geometry is quite complex so I have examine my model a little.
