.skm Materials
Took the basic "Metal_Steel_Textured" mat and added some grunge into gimp. Imported it back into SU and played around with the color filters to give me 2 other variations. As soon as they're painted onto an object they will be too big so scale back to the original size of the mat (about 152 I think
)First time doing this so let me know if you download them and they work.
Might do some more on concrete etc.Thanks.
Scott.
Metal_Steel_Textured_White.skm
Metal_Steel_Textured_White1.skm
Metal_Steel_Textured_White2.skm
Metal_Steel_Textured_White3.skm
Thanks.
FWIW, the one you call Metal_Steel_Textured_White is too large.
I sized the textures to match the original one. I think they should be the same in the attached.
Register LoginAdvertisement
