    Coordinates entered with InputBox
    5 Posts 2 Posters 1.0k Views 2 Watching
    • D
      davesexcel
      Very 1st attempt with Ruby Sketchup, I am trying to have somebody enter 3 numbers in input boxes and then draw the lines to create a rake.
      I don't know how to get the numbers entered into the coordinates.
      Thanks for any help in this
      Dave
      model = Sketchup.active_model
        entities = model.entities
        prompts = ["Hieght1", "Width","Height2"]
          defaults = [10,20,15]
          input = UI.inputbox prompts, defaults, "Rake Window."
          if input == false
          UI.messagebox("All Must Be Entered")
          else
          UI.messagebox("Rake has been Drawn, #{input}!")
          #Coordinates from inptut box
        pt1 = [0, 0, 0]
         pt2 = [0, 10, 0]#Height1
         new_face = entities.add_line pt1, pt2
        pt2 = [0, 10, 0]
         pt3 = [20, 15, 0]#Width
         new_face = entities.add_line pt2, pt3
        pt3 = [20, 15, 0]
         pt4 = [20, 0, 0]#Heights
         new_face = entities.add_line  pt3, pt4
        pt4 = [20, 0, 0]
         pt1 = [0, 0, 0]
         new_face = entities.add_line pt1, pt4
      Sketchup.send_action("viewFront;")
       Sketchup.send_action("viewTop;")
      • TIGT
        else
        a,b,c=input
        UI.messagebox("Rake DATA accepted!, #{input}!")
        Then use a, b or c as needed in your points...
        So when you have:
        make it
        pt2 = [0, b, 0]#Height1
        Your input would be logical as XYZ !!!
        It's aka RGB...
        Although you seem to want to use it as a weird set of ABC v XYZ coordinates...
        πŸ˜’
        • D
          davesexcel
          Thanks, it works
          • D
            davesexcel
            Thanks, with your help I managed to clean it up a bit.
            I can draw the face now instead of just drawing the lines.
            I am now trying to select the face and offsetting it(Insetting).
            I can get the code to select it but it does not inset it.
            This is the error I get.
            **Error: #<NameError: undefined local variable or methodselection' for main:Object>
            C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/first.rb:24
            (eval):24:in load' (eval):24**
            My final outcome will be to have a user input the rake dimensions. It will draw the rake and then draw the offset and move the offset to the right of the original.
            Basically, need the original, and then another one 1/4" smaller beside it.
            One thing at a time though
            This is the code I have so far.
            ` model = Sketchup.active_model
            if input == false
            else
            a,b,c=input
            #Coordinates from input box
            pt1 = [0, 0, 0]
            pt2 = [0, a, 0]
            pt3 = [b, c, 0]
            pt4 = [b,0,0]
            new_face = entities.add_face pt1, pt2, pt3, pt4
            Sketchup.send_action("viewFront:")
            Sketchup.send_action("viewTop:")
            #Select and offset
            model.selection.add( model.active_entities.to_a )
            newFace = selection[1].offset(-.25)`
            Thanks for any replies.
            • TIGT
              The last line
              is wrong!
              Try
              selection=model.selection newFace = selection[1].offset(-0.25)
              OR
              newFace = model.selection[1].offset(-0.25)
              πŸ˜„
              The error is actually quite clear - it is telling you that 'selection' hasn't been defined ...
              Note it's best to use 0.25 NOT .25
              Also how do you know what selection[1] is going to be ??? πŸ˜•
              The API's offset() method is to offset a point3d by a vector3d + an optional length
              BUT there is an offset() method that can be added for faces, edges etc - BUT this is added by another script [by Rick Wilson?], but I don't see you 'requiring' it at the start of your code... πŸ˜•
              πŸ˜’
              Another tip: your input...
              fixes the inputs as integers, if you want the input in inched use decimal numbers:
              defaults = [10.0, 20.0, 15.0]
              OR
              defaults = [10.inch, 20.inch, 15.inch]
