CFileException 3 - ERROR!
@krisidious said:
Just got one of these with 2015... no autosaves, 10 skb's none of any use. lost hours of work. HATE!
You should check this
I have setup windows and sketchup2015 overwrite the old.So my profile cause this problem.
Some one said this program need microsoft.NET Framework 4.0,try install it. -
still losing time on this...
moved file to desktop and set reset autosave and backup. (so it would be on main harddrive)
made sure program ran as admin. no help.
seems to be when I move geometry manually...
I think it's a plugin doing it. I'm getting it every 20 minutes or so. I lose everything back to open. autosave is deleted as error happens and backups start being made with every click of the ok button. the backups are of the last open. I saved myself last round by making save as copies.
you can see the crazy geometry move as the error happened. also happened later with pushpull.
hey Krisidious
I was just wondering if u finally found the solution to the problem
everything u described is happening with me exactly the same!!! -
I don't know if we have the same problem, base on what I have experienced, it also appears the moment I click Save As or Ctrl S..
What I did was I access Windows defender, click Settings, Click the Virus & threat protection settings, look for the Controlled folder access and turn it off..
Maybe it will solve your problem..
Register LoginAdvertisement
