    Volumetric visualization
    4 Posts 3 Posters 492 Views 3 Watching
      martinspixis
      Hello Experts!
      for study purposes I need to create a SketchUp Ruby script for volumetric visualization of radiation dose. Dose volume must be divided into voxels where each voxel have x;y;z coordinates and value V which represents dose intensity, besides the voxels must be colored in different colors regarding to value V. For example, if 5>V>3, then color = blue, but if 10>V>5, then color = green et cetera.
      Can someone suggest a script to modify for my needs or help solve this problem?
      P.S. I am not an IT professional, my field of study is physics, so scripting is not an ordinary activity for me πŸ˜„
      Thanks in advance,
      Martins
        How is the data input into SketchUp ?
        I imagine you don't want to type x,y,z,v in for every one !
        If it is the form of Comma Separated Values in a CSV file - read/writable in Excel - then as the data is plain text you can read in the lines as individual voxels.
        I recommend that 1 unit in the file is represented by 1" in SketchUp [makes the number crunching easier].
        So then we have an array called 'voxels' containing several array of [x,y,z,v] data.
        Your tool needs to start by making a 'voxel' component - I suggest a 1x1x1 cube - easily done by making a definition and adding a 1x1 face from 4 points and pushpulling it by 1.
        Next you need to set up some colored materials to use later [suggest material.alpha= opacity at ~0.4] - you can specify by name - e.g. 'red' or create your own colors etc.
        Now make add a group in the model.entities to contain the voxel 'instances'.
        Now iterate the vowels and to the group.entities add an instance of the voxel definition.
        Read that voxel's array x,y,z,v values - use .to_f to convert the imported strings into numbers
        Make a point3d based on these x,y,z values.
        Use that point3d in a new Transformation.
        instance = group.entities.add_instance(voxel, transformation)
        The new instance of a voxel is added at x,y,z, it uses the default material.
        Now use a series of 'case' or 'if' tests to decide on the 'instance.material=' you use for that instance.
        You can also set the instance.name=v.to_s so the Entity Info can tell you the exact value of a selected voxel.
        After all of the voxels are processed you now have a stack of cubes colored by their 'v'.
        If the color has transparency then you can see through them, or Xray view-mode ?
        There are several plugin/code examples on SCF for the reading of CSV data, use of .to_f, making materials/colors, making components, adding instances with transformations, making tests assigning materials and so on
        • AdamBA Offline
          AdamB
          Your best bet is to extract the iso-surface from your data using marching-cubes rather than generate zillions of cubes.
          It would mean you could create N colored surfaces representing each of your threshold values for V.
          If you're asking whether its a trivial 10 minute script. The answer is unfortunately, No. 😒
          Adam
            martinspixis
            Thank's to all, problem solved!
