    Video Card Question
    48 Posts 8 Posters 2.7k Views 8 Watching
    • G Offline
      Glenn at home
      You know Joe, getting a newer, used PC is not a bad idea. Here is a local CL add in your area that has 2 of those for $90 each.
      craigslist | Page Not Found
      (sandiego.craigslist.org)
      They are older but they do use PCIe video cards (the newer ones) and they are dual core, 64-bit cpus which will be far and away better than your P4 based system. I really would not spend any money on that old system. I had one just like it and while it was a good PC for the 6 years I had it just got to a point where it was not worth upgrading it.
      Search around a bit on CL and fins one local, this way you can maybe see it run and check it's condition before you buy.
      Good luck πŸ˜„
        Joe Wood
        Boy I don't know, then I'd have to transfer everything on this computer over onto the newer one and I've never done anything like that before. Is it that difficult?
        Joe Wood
        woodsshop.com/
        • G Offline
          Glenn at home
          Yeah you'd basically have to reinstall all applications and then transfer all files as well. That is the worst part of getting a new PC. It can be a pain but it's worth it when you get better hardware.
            sketch3d.de
            because of this investing in a new, capable PC which will last some time is probably a better choice then investing in some ol' stuff... desktops are cheap these times, this one w/ the GTX from above and SU will fly.
            Norbert
              solo
              Actually setting up a new machine is therapeutic, especially if you get one with a larger HDD or multiple HDD's, you get a clean fast uncluttered machine to start with, you can organize the install as you please, put stuff in the right places, only load what you need resulting in a slick fast 3D machine.
              http://www.solos-art.com
              • G Offline
                Glenn at home
                Good point from both Solo and Norbert.
                  Joe Wood
                  Well folks, I don't really need a fast slick computer, this one is doing just fine (especially after flashing the Bios whatever that means), except for the video card and even that is slowing my SUp only a little bit. I hardly ever do large complex models. Besides I want to get a laptop here pretty soon.
                  so, I'm a little confused about which card to get, could I get a link to a card I can just order?
                  Joe Wood
                  woodsshop.com/
                    sketch3d.de
                    @joe wood said:
                    ...except for the video card and even that is slowing my SUp only a little bit...
                    the CPU is the crucial issue for speed in SU. The video system needs to provide reliable OpenGL support first, which automatically means a dedicated and therefore capable video card to some extent.
                    The best/fastest/latest GeForce for ol' systems w/ AGP slot is the 7800 series. You can buy a new (expensive) GF 7800 GS at Amazon... or do a fall back to the cheaper and less power consumpting GF 7600 GS.
                    Good Luck again,
                    Norbert
                    • 3 / 3
