    Store Patterned Data
    4 Posts 2 Posters 423 Views 2 Watching
    • pingpinkP
      pingpink
      I'm trying to store patterned data to recheck the design for later use of different coloured panels.
      Process Steps :
      1. Select a patterned model.
      2. The patterns are convert into a group and in a layer "Patterns" and be invisible temporary.
      3. Only the sub-dividing faces are shown , later I can open the patterned group.
      The problem is the patterned group is copied and invisible , but the edges which are drawn in a layer " Patterns " cut and divide each face that is not a panel. I try to learn the code from Tig's example. Very good example , I wonder how can I clear the edges that cut faces ?
      def group_hide_patterns
      #EDGES-GROUP
      model=Sketchup.active_model
      edges=[]
      ss=model.selection
      ss.grep(Sketchup;;Face).each{|face| edges << face.edges}
      ss.grep(Sketchup;;Edge).each{|edge| edges << edge}
      edges.flatten!
      edges.uniq!
      edges.compact!
      ents=model.active_entities
      group=ents.add_group(edges)
      group.name="patterns"
      	edge_layer = model.layers.add("Patterns")
      	if group.name="patterns"
      	ss.each{|e|
      	e.layer = edge_layer  if e.is_a? Sketchup;;Group
      		edge_layer.visible = false
      Process Steps
      Problem
      Apply
      • TIGT
        Groups/components will separate geometry, so keeping panel divisions in a separate group.entities will mean they won't cut faces that remain inside in another entities context.
        It is much better to use layers to hide/show groups or component-instances and keep all of your raw geometry [edges and faces] on Layer0. Layers or using Hidden=true don't separate geometry.
        BUT if you have an edge that is splitting a face [i.e. they must all be in the same context] - aka a coplanar edge - then there are several examples of code to delete such edges.
        Here's one [pretty much unpublished] pick the meat off the bones...
        ### Delete Coplanar Edges
        # TIG (c) 2008-2013
        require 'sketchup.rb'
        module TIG
        def self.deleteCoplanarEdges_validate_selection()
        	Sketchup.active_model.selection.each{|e|
        		if e.is_a?(Sketchup;;Edge) && e.faces.length==2
        			return true
        			break
        		end#if
        	return false
        def self.deleteCoplanarEdges()
        	edges=model.selection.grep(Sketchup;;Edge).find_all{|e| e.faces.length==2 }
        	togos=[]
        	counter=0
        	model.start_operation("Delete Coplanar Edges")
        	edges.each{|e|
        		next unless e.valid?
        		if e.faces[0].normal.dot(e.faces[1].normal) > 0.99999999 && e.faces[0].material == e.faces[1].material && e.faces[0].back_material == e.faces[1].back_material
        			togos << e
        			counter+=1
        			Sketchup;;set_status_text(("Coplanar Edges Erased = #{counter}"),SB_PROMPT)
        		end#if
        	model.active_entities.erase_entities(togos)
        	model.commit_operation
        unless file_loaded?(__FILE__)
        	UI.add_context_menu_handler{|menu|
        		if self.deleteCoplanarEdges_validate_selection()
        			menu.add_item("Delete COPLANAR Edges"){self.deleteCoplanarEdges()}
        		end#if
        end#unless
        file_loaded(__FILE__)
        end#module
        • pingpinkP
          pingpink
          I rethink again , maybe I have to separate between panel faces and pattern group ? πŸ˜„
          Method
          • pingpinkP
            pingpink
            Thank You So much,Tig. It works ! πŸ˜„
            This is the idea to revise a model from architect by storing data at the first time. And later use to recheck data for tagging panels , and take the panel out in order that the facade engineer can do the life size panels to do mapping back on sub-dividing panels.
            The method I do :
            The subdividing faces are in the "Layer0".
            The patterns are in the Layer-"Patterns".
            So , they are not mix together in the same layer.
            For the shortage time to "delete coplanar edges or patterns" , I have to select edges by degrees and use your code to delete edges because the group edge and original edges are overlap that I have to delete original edges.So , it doesn't affect to bring tagging panels out , and I can recheck the patterned data to do retag panels.
            For the store patterned data , maybe it comprise of 3 functions :
            1.Make edge group
            2.Select Coplanar edges by degrees
            3.Delete Coplanar edges selection
