    DWG Export Crashes
    1 Posts 1 Posters 1.3k Views 1 Watching
    • B
      bluegravy
      I have noted several threads on the subject of DWG Export crashes and there doesn't seem to be an answer which helps my current problem. I am trying to export a model I created under SketchUp Pro 8.0.16845. It is only 12MB but it does have a large number of trees and plants which have a large number of faces.
      Every time I try to export to any of the DWG or DXF files SketchUp hangs for a few moments and then crashes. I have tried some of the suggestions of other threads such as moving the origin to the centre of the model, reducing the export options, restarting my MAC and SketchUp, and resetting the workspace.
      As a garden designer I quite frequently need to exchange DWG files with architects or builders and was one of the main reasons I upgraded to Sketchup Pro.
      Any suggestions gratefully received.
      I have attached the log output.
      Peter Davis
      Garden Designer
      http://www.hampshire-gardendesign.co.uk
      Process: SketchUp [626]
      Path: /Applications/Google SketchUp 8/SketchUp.app/Contents/MacOS/SketchUp
      Identifier: com.google.sketchuppro8
      Version: 8.0 (8.0.16845)
      Code Type: X86 (Native)
      Parent Process: launchd [274]
      Date/Time: 2013-10-27 09:57:17.745 +0000
      OS Version: Mac OS X 10.7.5 (11G63b)
      Report Version: 9
      Interval Since Last Report: 20928 sec
      Crashes Since Last Report: 20
      Per-App Interval Since Last Report: 4155 sec
      Per-App Crashes Since Last Report: 20
      Anonymous UUID: F3B0468D-54D4-4090-A052-8EC85A3B6580
      Crashed Thread: 0 Dispatch queue: com.apple.main-thread
      Exception Type: EXC_CRASH (SIGABRT)
      Exception Codes: 0x0000000000000000, 0x0000000000000000
      Application Specific Information:
      objc[626]: garbage collection is OFF
      abort() called
      terminate called throwing an exception
      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
      0 libsystem_kernel.dylib 0x9bdc69c6 __pthread_kill + 10
      1 libsystem_c.dylib 0x99e65f78 pthread_kill + 106
      2 libsystem_c.dylib 0x99e56bdd abort + 167
      3 libc++abi.dylib 0x9c496921 abort_message + 94
      4 libc++abi.dylib 0x9c4941bc default_terminate() + 36
      5 libc++abi.dylib 0x9c4941fe safe_handler_caller(void ()()) + 15
      6 libc++abi.dylib 0x9c494268 std::terminate() + 23
      7 libc++abi.dylib 0x9c4952a0 __cxa_throw + 112
      8 DWGDirect 0x01408294 OdDbSymbolTable::add(OdDbSymbolTableRecord
      ) + 384
      9 DWGDirect 0x00d3c64e OdDbBlockTable::add(OdDbSymbolTableRecord*) + 1110
      10 Skp2Acad 0x0eef2e4d CAcadExporter::WriteDefinition(OdDbObjectId const&, ISkpComponentDefinition*) + 369
      11 Skp2Acad 0x0eefa498 CAcadExporter::WriteDefinitions(OdDbObjectId const&) + 150
      12 Skp2Acad 0x0eefb6dc CAcadExporter::WriteModel() + 128
      13 Skp2Acad 0x0eefb85a CAcadExporter::WriteFile(bool, bool, bool, bool, bool) + 62
      14 Skp2Acad 0x0eeec263 A2WHelper(char const*, unsigned short*, unsigned long) + 4389
      15 com.google.sketchuppro8 0x00138e9a std::vector<long, std::allocator<long> >::reserve(unsigned long) + 5758
      16 com.apple.Foundation 0x97a53792 __NSFireDelayedPerform + 615
      17 com.apple.CoreFoundation 0x9be2f2a6 CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION + 22
      18 com.apple.CoreFoundation 0x9be2ec37 __CFRunLoopDoTimer + 743
      19 com.apple.CoreFoundation 0x9be0dcd0 __CFRunLoopRun + 1888
      20 com.apple.CoreFoundation 0x9be0d1dc CFRunLoopRunSpecific + 332
      21 com.apple.CoreFoundation 0x9be0d088 CFRunLoopRunInMode + 120
      22 com.apple.HIToolbox 0x92cc2543 RunCurrentEventLoopInMode + 318
      23 com.apple.HIToolbox 0x92cc97d6 ReceiveNextEventCommon + 168
      24 com.apple.HIToolbox 0x92cc971a BlockUntilNextEventMatchingListInMode + 88
      25 com.apple.AppKit 0x95eb1ee8 _DPSNextEvent + 678
      26 com.apple.AppKit 0x95eb1752 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 113
      27 com.apple.AppKit 0x95eadac1 -[NSApplication run] + 911
      28 com.apple.AppKit 0x9613eac5 NSApplicationMain + 1054
      29 com.google.sketchuppro8 0x00032402 std::_Rb_tree<std::string, std::pair<std::string const, long ()(CEntity, CFUUIDBytes, void**)>, std::_Select1st<std::pair<std::string const, long ()(CEntity, CFUUIDBytes, void**)> >, std::lessstd::string, std::allocator<std::pair<std::string const, long ()(CEntity, CFUUIDBytes, void**)> > >::insert_unique(std::_Rb_tree_iterator<std::pair<std::string const, long ()(CEntity, CFUUIDBytes, void**)> >, std::pair<std::string const, long ()(CEntity, CFUUIDBytes, void**)> const&) + 13670
      Thread 1:: Dispatch queue: com.apple.libdispatch-manager
      0 libsystem_kernel.dylib 0x9bdc790a kevent + 10
      1 libdispatch.dylib 0x97e38e04 _dispatch_mgr_invoke + 969
      2 libdispatch.dylib 0x97e37853 _dispatch_mgr_thread + 53
      Thread 2:
      0 libsystem_kernel.dylib 0x9bdc4c22 mach_msg_trap + 10
      1 libsystem_kernel.dylib 0x9bdc41f6 mach_msg + 70
      2 com.googlecode.google-breakpad 0x02418bec google_breakpad::ExceptionHandler::WaitForMessage(void*) + 116
      3 libsystem_c.dylib 0x99e63ed9 _pthread_start + 335
      4 libsystem_c.dylib 0x99e676de thread_start + 34
      Thread 3:: com.apple.NSURLConnectionLoader
      2 com.apple.CoreFoundation 0x9be049da __CFRunLoopServiceMachPort + 170
      3 com.apple.CoreFoundation 0x9be0db04 __CFRunLoopRun + 1428
      4 com.apple.CoreFoundation 0x9be0d1dc CFRunLoopRunSpecific + 332
      5 com.apple.CoreFoundation 0x9be0d088 CFRunLoopRunInMode + 120
      6 com.apple.Foundation 0x97ab30c4 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 378
      7 com.apple.Foundation 0x97aa6e25 -[NSThread main] + 45
      8 com.apple.Foundation 0x97aa6dd5 NSThread__main + 1582
      9 libsystem_c.dylib 0x99e63ed9 _pthread_start + 335
      10 libsystem_c.dylib 0x99e676de thread_start + 34
      Thread 4:: com.apple.CFSocket.private
      0 libsystem_kernel.dylib 0x9bdc6b42 __select + 10
      1 com.apple.CoreFoundation 0x9be5be15 __CFSocketManager + 1557
      2 libsystem_c.dylib 0x99e63ed9 _pthread_start + 335
      3 libsystem_c.dylib 0x99e676de thread_start + 34
      Thread 5:: WebCore: LocalStorage
      0 libsystem_kernel.dylib 0x9bdc683e __psynch_cvwait + 10
      1 libsystem_c.dylib 0x99e67e21 _pthread_cond_wait + 827
      2 libsystem_c.dylib 0x99e1842c pthread_cond_wait$UNIX2003 + 71
      3 com.apple.JavaScriptCore 0x996bf5d1 WTF::ThreadCondition::timedWait(WTF::Mutex&, double) + 81
      4 com.apple.WebCore 0x9a4a2e11 WTF::MessageQueueWebCore::LocalStorageTask::waitForMessage() + 135
      5 com.apple.WebCore 0x9a4a2d64 WebCore::LocalStorageThread::threadEntryPoint() + 74
      6 com.apple.WebCore 0x9a4a2cc1 WebCore::LocalStorageThread::threadEntryPointCallback(void*) + 17
      7 libsystem_c.dylib 0x99e63ed9 _pthread_start + 335
      8 libsystem_c.dylib 0x99e676de thread_start + 34
      Thread 6:: JavaScriptCore::Marking
      Thread 7:: JavaScriptCore::Marking
      Thread 8:: JavaScriptCore::Marking
      Thread 9:: JavaScriptCore::BlockFree
      2 libsystem_c.dylib 0x99e183e0 pthread_cond_timedwait$UNIX2003 + 70
      3 com.apple.JavaScriptCore 0x996bf61c WTF::ThreadCondition::timedWait(WTF::Mutex&, double) + 156
      4 com.apple.JavaScriptCore 0x9990cb93 JSC::Heap::blockFreeingThreadMain() + 323
      5 com.apple.JavaScriptCore 0x9990cbcf JSC::Heap::blockFreeingThreadStartFunc(void*) + 15
      6 libsystem_c.dylib 0x99e63ed9 _pthread_start + 335
      7 libsystem_c.dylib 0x99e676de thread_start + 34
      Thread 10:
      Thread 11:
      0 libsystem_kernel.dylib 0x9bdc702e __workq_kernreturn + 10
      1 libsystem_c.dylib 0x99e65ccf _pthread_wqthread + 773
      2 libsystem_c.dylib 0x99e676fe start_wqthread + 30
      Thread 12:
      Thread 13:
      Thread 14:
      Thread 15:
      Thread 16:: com.apple.appkit-heartbeat
      0 libsystem_kernel.dylib 0x9bdc6bb2 __semwait_signal + 10
      1 libsystem_c.dylib 0x99e187b9 nanosleep$UNIX2003 + 187
      2 libsystem_c.dylib 0x99e18558 usleep$UNIX2003 + 60
      3 com.apple.AppKit 0x960f66da -[NSUIHeartBeat _heartBeatThread:] + 2399
      4 com.apple.Foundation 0x97aa6e25 -[NSThread main] + 45
      5 com.apple.Foundation 0x97aa6dd5 NSThread__main + 1582
      Thread 17:
      Thread 18:
      Thread 0 crashed with X86 Thread State (32-bit):
      eax: 0x00000000 ebx: 0x9c497330 ecx: 0xbfffe0dc edx: 0x9bdc69c6
      edi: 0xacf142c0 esi: 0x00000006 ebp: 0xbfffe0f8 esp: 0xbfffe0dc
      ss: 0x00000023 efl: 0x00000246 eip: 0x9bdc69c6 cs: 0x0000000b
      ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
      cr2: 0x9bf7f0a2
      Logical CPU: 0
      Binary Images:
      0x1000 - 0x7cefeb +com.google.sketchuppro8 (8.0 - 8.0.16845) <B2296FC5-BC8A-AD19-7628-44C612F4DA89> /Applications/Google SketchUp 8/SketchUp.app/Contents/MacOS/SketchUp
      0x9f1000 - 0xa9eff7 libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <7B6DB792-C9E5-3772-8734-8D0052757B8C> /usr/lib/libcrypto.0.9.7.dylib
      0xae3000 - 0xb0cfff +libGeometry.dylib (??? - ???) <24F360E5-7AEE-4D39-FF16-D9BFFBAA9539> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libGeometry.dylib
      0xb29000 - 0xb39ff3 +libCommonImage.dylib (??? - ???) <4360DFDA-D823-FF4A-2688-8EF868A907AE> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libCommonImage.dylib
      0xb47000 - 0xb49ffb +libCommonGeoutils.dylib (??? - ???) <E0BE6B8A-2247-E315-F7CB-30A44F3C492C> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libCommonGeoutils.dylib
      0xb4d000 - 0xb58ff7 +libCommonInternet.dylib (??? - ???) <E5B1F973-8F20-1DCF-9522-82625E140D50> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libCommonInternet.dylib
      0xb61000 - 0xb84feb +libCommonUtils.dylib (??? - ???) <B4FC6F73-03B8-CF32-9FFA-6970286258B3> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libCommonUtils.dylib
      0xb9b000 - 0xba6fff +libCommonWarehouseapi.dylib (??? - ???) <8087B89B-723F-B227-1CFE-42FF72BB6071> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libCommonWarehouseapi.dylib
      0xbad000 - 0xbccffb +com.google.sketchup.ALAppKit (??? - 1.0) <70E356E3-CCBE-990C-FE01-2FFA4E2BFCB1> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/ALAppKit.framework/Versions/A/ALAppKit
      0xbde000 - 0x1cdcfe7 +DWGDirect (??? - ???) <B103FA4C-700D-1A02-F34A-59630B2D93E2> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/DWGDirect.framework/Versions/A/DWGDirect
      0x2417000 - 0x241cffe +com.googlecode.google-breakpad (??? - 1.0) <2074B004-A549-1A7A-1859-19FEC79287C6> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/Breakpad.framework/Versions/A/Breakpad
      0x2424000 - 0x24e4fcb +com.google.rubyframework (??? - 1.0) /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/A/Ruby
      0x2510000 - 0x2519ffb +com.Google.WebDialog (??? - 1.0) <B56716AD-3D3A-3C1A-3B19-438B0D113CFB> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/WebDialog.framework/Versions/A/WebDialog
      0x251f000 - 0x2737fc7 +Xerces (??? - ???) /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/Xerces.framework/Versions/A/Xerces
      0x2970000 - 0x2d4bfe2 +libgdal.dylib (15.2.0 - compatibility 15.0.0) <08DCECA1-F4BA-E09A-903F-A977059701C5> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libgdal.dylib
      0x2e88000 - 0x2eb9fff +libproj.dylib (7.6.0 - compatibility 7.0.0) <CF43E4A9-B91A-F86B-F506-95131DE4E3EC> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libproj.dylib
      0x2ec6000 - 0x2ee3ffc +libjpeg.62.dylib (63.0.0 - compatibility 63.0.0) <EC8BA7B7-B515-C96A-F08D-A31D7302D8B8> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libjpeg.62.dylib
      0x2eea000 - 0x2f1ffff +libpaintlib.1.dylib (2.0.0 - compatibility 2.0.0) <E71C2410-9C62-ED88-3188-975B8F6D42ED> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libpaintlib.1.dylib
      0x2f43000 - 0x2f64fe3 +libpng12.0.dylib (48.0.0 - compatibility 48.0.0) <13C20505-FA35-B735-BE6D-853F4E0295B8> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libpng12.0.dylib
      0x2f6b000 - 0x2fb9fef +libtiff.3.dylib (12.2.0 - compatibility 12.0.0) <0C518DFA-C202-72A3-21D9-8E0C293F29B6> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libtiff.3.dylib
      0x2fc4000 - 0x2fc9fff +libgif.4.dylib (6.6.0 - compatibility 6.0.0) <D9CC53C0-76FB-A490-CC5B-EF144F52BAD6> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libgif.4.dylib
      0x2fce000 - 0x2fddfff +libAlchemyExt.dylib (??? - ???) <72749C0F-23EB-03F6-3EE9-9DB0F3CE8165> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libAlchemyExt.dylib
      0x2ffa000 - 0x3019fff +libIGAttrs.dylib (??? - ???) <730B1018-8410-8BC0-A20E-519E6EF31E15> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libIGAttrs.dylib
      0x306a000 - 0x30caff8 +libIGCore.dylib (??? - ???) <926B8196-FA4C-F09D-A482-7527DEF5398F> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libIGCore.dylib
      0x314f000 - 0x33d4fe7 +libIGGfx.dylib (??? - ???) <F5682A54-9FD0-642C-F684-E9D6D984C602> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libIGGfx.dylib
      0x34c6000 - 0x34e7ffa +libIGMath.dylib (??? - ???) <43C369B4-9A6D-F89C-3168-DC09785AA9FE> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libIGMath.dylib
      0x3512000 - 0x3582fff +libIGSg.dylib (??? - ???) <C8085D42-4CB5-E6A3-D4C8-24BC562D61E1> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libIGSg.dylib
      0x361d000 - 0x362afff +libIGUtils.dylib (??? - ???) <974A5216-00FA-AC9D-00AF-3111D9D43283> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libIGUtils.dylib
      0x3649000 - 0x3676ffb +libCommonXML.dylib (??? - ???) <69793631-6EC5-CE0C-1967-81D402F727D9> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/libCommonXML.dylib
      0x3691000 - 0x36a0ff7 +breakpadUtilities.dylib (??? - ???) <5705C015-5A14-2DC0-965A-B8891FDD0D77> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/Breakpad.framework/Versions/A/Resources/breakpadUtilities.dylib
      0x476e000 - 0x476effd +cl_kernels (??? - ???) <AD742ACF-DDE6-457A-9058-AFEA5D5671DE> cl_kernels
      0x8ff7000 - 0x8ff8ff7 +SketchUp (??? - 0.0.1d1) <7D3F250A-11C9-A438-786F-B7395152004F> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/SketchUp.framework/Versions/A/SketchUp
      0xd95a000 - 0xd9a7ff7 +3dsExporter (3DS Exporter Version 6.0 - 0.0.1d1) <67A30303-7E09-4299-1813-25815302811A> /Applications/Google SketchUp 8/SketchUp.app/Contents/PlugIns/3dsExporter.plugin/Contents/MacOS/3dsExporter
      0xd9c4000 - 0xd9d4ff7 +com.atlast.importers.3ds (??? - 1.0) <EE6DAA60-D461-6BCB-172F-1441759FA79B> /Applications/Google SketchUp 8/SketchUp.app/Contents/PlugIns/3DSImporter.plugin/Contents/MacOS/3DSImporter
      0xd9e7000 - 0xdc32ff7 +com.google.sketchup.sapi (??? - 1.0) <4BF53D5B-3C5C-D7C7-562B-DC5AA3C95867> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/SAPI.framework/Versions/A/SAPI
      0xdd8d000 - 0xdd9eff7 +lib3ds.dylib (??? - ???) <C49CAB13-F949-8713-16C5-8B594835296F> /Applications/Google SketchUp 8/SketchUp.app/Contents/PlugIns/3DSImporter.plugin/Contents/Frameworks/lib3ds.dylib
      0xdda5000 - 0xe02bfff +com.google.sketchup.collada (??? - 1.0) <5D886C83-EBBC-F749-960A-1285697889D0> /Applications/Google SketchUp 8/SketchUp.app/Contents/PlugIns/collada.plugin/Contents/MacOS/collada
      0xe19c000 - 0xe3a1ff3 +slapi (??? - ???) <51E0FCE3-8414-E070-EC67-0200E5442046> /Applications/Google SketchUp 8/SketchUp.app/Contents/Frameworks/slapi.framework/Versions/A/slapi
      0xe4ac000 - 0xe4daff3 +ObjExporter (OBJ Exporter version 6.0 - 0.0.1d1) <4A15378D-5548-C305-E385-CE05AADBB3D5> /Applications/Google SketchUp 8/SketchUp.app/Contents/PlugIns/ObjExporter.plugin/Contents/MacOS/ObjExporter
      0xe600000 - 0xe621ff3 +com.atlast.demimporter (??? - 1.0) <2B7B98B5-0967-E668-4924-E45D186555D5> /Applications/Google SketchUp 8/SketchUp.app/Contents/PlugIns/DEMImporter.plugin/Contents/MacOS/DEMImporter
      0xe677000 - 0xec25fef +FbxExporter (FBX Exporter Version 8.0 - 0.0.1d1) <E3D1DF98-367F-F1B5-4AEF-07C6B1746C01> /Applications/Google SketchUp 8/SketchUp.app/Contents/PlugIns/FbxExporter.plugin/Contents/MacOS/FbxExporter
      0xeee9000 - 0xef2affb +Skp2Acad (??? - 0.1) <808EDF3B-607E-5C30-F630-9E5B29CC3CD5> /Applications/Google SketchUp 8/SketchUp.app/Contents/PlugIns/Skp2Acad.plugin/Contents/MacOS/Skp2Acad
      0xef4d000 - 0xef81fe3 +com.atlast.Skp2AcadHlr (??? - 1.0) <2A5A8FA2-EC84-8D30-6580-AA8ABD852071> /Applications/Google SketchUp 8/SketchUp.app/Contents/PlugIns/Skp2AcadHlr.plugin/Contents/MacOS/Skp2AcadHlr
      0xef9e000 - 0xefd1ff7 +com.atlast.Skp2AcadSection (??? - 1.0) <346292DE-AA83-80E7-1D17-2DAA4DBD98A6> /Applications/Google SketchUp 8/SketchUp.app/Contents/PlugIns/Skp2AcadSection.plugin/Contents/MacOS/Skp2AcadSection
      0xefed000 - 0xf01dffb +VRMLExporter (XSI Exporter Version 6.0 - 0.0.1d1) <F0433B52-71C5-4535-0594-2334E0C0AC9A> /Applications/Google SketchUp 8/SketchUp.app/Contents/PlugIns/VRMLExporter.plugin/Contents/MacOS/VRMLExporter
      0xf034000 - 0xf06aff7 +XsiExporter (XSI Exporter Version 6.0 - 0.0.1d1) <4BA199DB-43BD-8E7C-CCCB-8D8BEB75950A> /Applications/Google SketchUp 8/SketchUp.app/Contents/PlugIns/XsiExporter.plugin/Contents/MacOS/XsiExporter
      0x11cff000 - 0x11d01fff libCoreFSCache.dylib (??? - ???) <9E7CBE71-566C-36E9-A49F-C5FF6956D76F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
      0x11d0c000 - 0x11d17ff3 com.apple.Librarian (1.0.1 - 1) <6027262F-2CBF-3410-AF40-8654577CAD59> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
      0x11d23000 - 0x11d44ff7 com.apple.ChunkingLibrary (1.0 - 127.2) <8C1C8488-71E4-3C13-AF75-95CF06C040A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
      0x11e43000 - 0x11e4cff6 libcldcpuengine.dylib (2.0.19 - compatibility 1.0.0) <95A88DC8-E5EE-363F-9275-214D5AB7A2EF> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
      0x11e55000 - 0x11e8fff3 com.apple.Ubiquity (1.1 - 210.2) <F8426ABA-BB3F-3A48-BF4E-9A0F6C12634F> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
      0x11fe9000 - 0x11fe9ff7 +cl_kernels (??? - ???) <AF4BBDD2-B602-47CB-8381-84AA1AD6C957> cl_kernels
      0x11fef000 - 0x11ff0ff1 +cl_kernels (??? - ???) <C8BA8408-7945-45C3-B1B1-E0E60D1AE32E> cl_kernels
      0x11ff8000 - 0x11ff9ff5 +cl_kernels (??? - ???) <C90AA7E1-04C5-45A5-903D-601B602F7B53> cl_kernels
      0x12031000 - 0x12032ffd +cl_kernels (??? - ???) <DD27496E-4331-4669-9C1D-47FD6522EDC8> cl_kernels
      0x1204c000 - 0x1204cff7 +cl_kernels (??? - ???) <5A65FE83-F2B0-41AB-AEA5-02AFC4F34838> cl_kernels
      0x1204e000 - 0x120f3ff7 unorm8_rgba.dylib (2.0.19 - compatibility 1.0.0) <58EF82E1-2227-38BD-B298-47BC1D149789> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
      0x12108000 - 0x12108ff1 +cl_kernels (??? - ???) <0827C63E-3345-499B-B7F2-72F5B40F5FB2> cl_kernels
      0x1210a000 - 0x121b2ff7 unorm8_bgra.dylib (2.0.19 - compatibility 1.0.0) <99A967D2-5577-396B-BD11-56EAFF962AB2> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
      0x14624000 - 0x14630ffb libGPUSupport.dylib (??? - ???) <A4467427-9E43-3F03-96E7-B09BBD5F0A6D> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
      0x182ac000 - 0x182d9ff0 GLRendererFloat (??? - ???) <B72FCE8D-7A5E-35F3-8A9F-0D139F8921AB> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
      0x19900000 - 0x19a88ff9 GLEngine (??? - ???) <84549EEF-900F-397A-AABC-47DD261F40BE> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
      0x19abf000 - 0x19c29ffb libGLProgrammability.dylib (??? - ???) <169ED314-B937-3877-A7D7-4AFB96D8C561> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
      0x1a800000 - 0x1aa9cff3 com.apple.ATIRadeonX3000GLDriver (7.32.12 - 7.3.2) <86BEF6D7-D130-36AB-8939-5AB20C0681FE> /System/Library/Extensions/ATIRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000GLDriver
      0x1aad1000 - 0x1ae52fef com.apple.driver.AppleIntelHD3000GraphicsGLDriver (7.32.12 - 7.3.2) <AB1CE0F6-8FD8-384E-9DE9-A31DDD0607BD> /System/Library/Extensions/AppleIntelHD3000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD3000GraphicsGLDriver
      0x8fe5c000 - 0x8fe8eaa7 dyld (195.6 - ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld
      0x90005000 - 0x90009fff com.apple.CommonPanels (1.2.5 - 94) <3A988595-DE53-34ED-9367-C9A737E2AF38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
      0x9000a000 - 0x9002dfff com.apple.CoreVideo (1.7 - 70.3) <4234C11C-E8E9-309A-9465-27D6D7458895> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
      0x9002e000 - 0x90035ff7 libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
      0x90036000 - 0x9005bff9 libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
      0x9005c000 - 0x900b5fff com.apple.HIServices (1.21 - ???) <91EC636D-AC27-3332-BA1C-FD7301917429> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
      0x900b6000 - 0x904b8ff6 libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
      0x904b9000 - 0x904bcfff com.apple.AppleSystemInfo (1.0 - 1) <D2F60873-ECB1-30A8-A02E-E772F969116E> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
      0x904bd000 - 0x904eaff9 com.apple.securityinterface (5.0 - 55022.6) <0FA3E84B-B5FF-3A58-A408-46280982CACC> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
      0x904eb000 - 0x904f1ffd com.apple.CommerceCore (1.0 - 17.1) <32AB16CE-7BBB-3124-8C42-2EE3E1D336F0> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
      0x904f2000 - 0x905b2ffb com.apple.ColorSync (4.7.4 - 4.7.4) <0A68AF35-15DF-3A0A-9B17-70CE2A106A6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
      0x90600000 - 0x90664fff com.apple.framework.IOKit (2.0 - ???) <94827954-5906-36C4-819B-24CDAFD85C72> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
      0x90665000 - 0x90669ffa libcache.dylib (47.0.0 - compatibility 1.0.0) <98A82BC5-0DD9-3212-9CAE-35A77278EEB6> /usr/lib/system/libcache.dylib
      0x9067d000 - 0x906dfffb com.apple.datadetectorscore (3.0 - 179.4) <3A418498-C189-37A1-9B86-F0ECB33AD91C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
      0x906e0000 - 0x906e8fff com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
      0x906e9000 - 0x90717ff7 com.apple.DictionaryServices (1.2.1 - 158.3) <8D03D180-D834-39F3-A106-78E0B22A7893> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
      0x90718000 - 0x90718fff com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
      0x90725000 - 0x90754ff7 libsystem_info.dylib (??? - ???) <37640811-445B-3BB7-9934-A7C99848250D> /usr/lib/system/libsystem_info.dylib
      0x90755000 - 0x9082dff6 com.apple.QuickLookUIFramework (3.2 - 500.18) <CE281BD9-C1CF-3F87-BD22-412ED253580E> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
      0x9082e000 - 0x9087fff9 com.apple.QuickLookFramework (3.2 - 500.18) <CF3EF345-EA3E-3C2D-B56D-E4433326254A> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
      0x90880000 - 0x90887ff9 libsystem_dnssd.dylib (??? - ???) <EBEAF723-84F8-3544-8FB2-31B7771B50D0> /usr/lib/system/libsystem_dnssd.dylib
      0x90888000 - 0x90898fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
      0x90899000 - 0x908a4ffb com.apple.speech.recognition.framework (4.0.21 - 4.0.21) <A1764D2F-EB84-33DC-9ED5-CDA3B468FF3E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
      0x90915000 - 0x9093efff com.apple.shortcut (2.1 - 2.1) <60000F49-6309-34B1-88A1-588DC566C8DF> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
      0x90958000 - 0x90963ff3 libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <D6E17FD4-ECA0-3EEE-BFC5-F6A42A21AB5D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
      0x90964000 - 0x90967ff7 libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
      0x90969000 - 0x90969fff com.apple.Cocoa (6.6 - ???) <650273EF-1ABC-334E-B745-B75AF028F9F4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
      0x9096a000 - 0x90c6cfff com.apple.CoreServices.CarbonCore (960.25 - 960.25) <C613B0DA-B401-3DC7-B626-6E20D4DDC8A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
      0x90c6d000 - 0x90d03ff7 com.apple.LaunchServices (480.40 - 480.40) <D5C0DEF9-398C-3742-8C4E-875C3365EC8B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
      0x90d04000 - 0x90d0affb com.apple.print.framework.Print (7.4 - 247.3) <CB075EEE-FA1F-345C-A1B5-1AB266FC73A1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
      0x90d0b000 - 0x90d0bfff libOpenScriptingUtil.dylib (??? - ???) <E4C22B65-9493-31D5-9D46-19BD70975587> /usr/lib/libOpenScriptingUtil.dylib
      0x90d0c000 - 0x90d0eff9 com.apple.securityhi (4.0 - 1) <BD367302-73C3-32F4-8080-E389AE89E434> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
      0x90d0f000 - 0x90d29fff com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
      0x90d2a000 - 0x90d2fff7 libmacho.dylib (800.0.0 - compatibility 1.0.0) <56A34E97-518E-307E-8218-C5D43A33EE34> /usr/lib/system/libmacho.dylib
      0x90d30000 - 0x90d67fef com.apple.DebugSymbols (2.1 - 87) <EB951B78-31A5-379F-AFA1-B5C9A7BB3D23> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
      0x90d68000 - 0x90f93ffb com.apple.QuartzComposer (5.0 - 236.10) <416993F4-2868-35FF-90DE-34C93D83574F> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
      0x910cc000 - 0x910cfff9 libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <16DCE20A-9790-369A-94C1-B7954B418C77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
      0x910d0000 - 0x910d1fff liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
      0x910d2000 - 0x910dbffc com.apple.DisplayServicesFW (2.5.4 - 323.3) <820C4B45-814A-3101-A1FA-044CA6D2FBC8> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
      0x910dc000 - 0x912d4ff7 com.apple.CoreData (104.1 - 358.14) <C1730963-F75D-3338-B65F-D50235538B28> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
      0x9130f000 - 0x91322ff8 com.apple.MultitouchSupport.framework (231.4 - 231.4) <083F7787-4C3B-31DA-B5BB-1993D9A9723D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
      0x91327000 - 0x91656ff7 com.apple.FinderKit (1.0.5 - 1.0.5) <5F2FB244-8734-31FA-A957-0F4B603E02BB> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
      0x91657000 - 0x9165eff8 libCGXCoreImage.A.dylib (600.0.0 - compatibility 64.0.0) <4F9DD9D1-F251-3661-A3C6-B1F550B084B0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
      0x91c7e000 - 0x91cdcff7 com.apple.coreui (1.2.2 - 165.11) <340B0B83-1407-3AB4-BCAB-505C29303EE2> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
      0x91cdd000 - 0x92098ffb com.apple.SceneKit (125.3 - 125.8) <89008B87-87E7-3972-A274-30311497EE32> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/SceneKit
      0x920cb000 - 0x92167ffe com.apple.PDFKit (2.7.8 - 2.7.8) <2DFB71DA-158B-375B-AA75-532AF883EAAA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
      0x92168000 - 0x9223fff3 com.apple.avfoundation (2.0 - 180.50) <7B7FDF30-AC40-3715-A409-B5A27F7B5585> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
      0x92253000 - 0x92290fef libGLImage.dylib (??? - ???) <FC13D46F-69C4-3BA1-A5E8-52C2EC8B7D58> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
      0x92385000 - 0x92cb072b com.apple.CoreGraphics (1.600.0 - ???) <DD7CDD67-FC4F-36FE-962F-2EA7EF3FC780> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
      0x92cb1000 - 0x92cbfff7 libxar-nossl.dylib (??? - ???) <5BF4DA8E-C319-354A-967E-A0C725DC8BA3> /usr/lib/libxar-nossl.dylib
      0x92cc0000 - 0x93006ff3 com.apple.HIToolbox (1.9 - ???) <E5EA9EEF-3CCA-36A0-8688-DA2E64E2256C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
      0x93007000 - 0x93094fe7 libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
      0x93095000 - 0x93194ffb com.apple.DiskImagesFramework (10.7.4 - 331.7) <31A74A7E-E2AE-313D-A7C4-6DFCF0F22C9A> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
      0x93195000 - 0x931bfff1 com.apple.CoreServicesInternal (113.19 - 113.19) <F7A309D1-DCB4-38DE-8248-E16D0182AA6C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
      0x931c0000 - 0x93200ff7 libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
      0x93316000 - 0x9338afff com.apple.CoreSymbolication (2.2 - 73.2) <FA9305CA-FB9B-3646-8C41-FF8DF15AB2C1> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
      0x933eb000 - 0x93453fff libc++.1.dylib (28.4.0 - compatibility 1.0.0) <B24814AB-CA77-3B9D-8FAB-58C9B4FD3A16> /usr/lib/libc++.1.dylib
      0x93454000 - 0x93491ff7 libcups.2.dylib (2.9.0 - compatibility 2.0.0) <007A1877-E981-3007-A8FA-9B179F4ED6D1> /usr/lib/libcups.2.dylib
      0x9349a000 - 0x934d0ff7 com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
      0x937aa000 - 0x937acffb libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
      0x9386b000 - 0x93b3affb com.apple.security (7.0 - 55148.6) <8DF67BDD-C98F-3B7E-AC63-D468407FA82D> /System/Library/Frameworks/Security.framework/Versions/A/Security
      0x93b3b000 - 0x93c1cff7 com.apple.DiscRecording (6.0.4 - 6040.4.1) <08BADDAD-FA79-3872-9387-EEE2A9FAA2F0> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
      0x93c1d000 - 0x93c95ff8 com.apple.CorePDF (3.1 - 3.1) <0074267B-F74A-30FC-8508-A14C821F0771> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
      0x93c96000 - 0x93ce5ffb com.apple.AppleVAFramework (5.0.16 - 5.0.16) <1188E7AB-76FE-343F-9108-30CD67E5A37B> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
      0x93d0f000 - 0x93d71ff3 libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
      0x93d72000 - 0x93e89fe9 com.apple.WebKit (7534.57 - 7534.57.7) <85DAC34E-86A1-380F-B166-56630C9B0BD5> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
      0x93e8a000 - 0x93ec5fff com.apple.bom (11.0 - 183) <39257FE6-8B23-39B6-9528-57184104A98F> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
      0x93ec6000 - 0x93f6afff com.apple.QD (3.40.1 - ???) <B5650C5E-AB41-3758-84A1-5A97EDCD8EFE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
      0x93f6b000 - 0x93f8cfff com.apple.framework.internetaccounts (1.2 - 3) <A93D14F6-DF12-3918-90E9-B73DD7B6456D> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
      0x93f8d000 - 0x93fcdff7 com.apple.NavigationServices (3.7 - 193) <16A8BCC8-7343-3A90-88B3-AAA334DF615F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
      0x93fce000 - 0x94033ff7 libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
      0x94034000 - 0x942a8ff3 com.apple.CoreImage (7.99.1 - 1.0.1) <C4B2DD2A-8E45-31CD-9B25-2AC1CA252B14> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
      0x944d6000 - 0x9451afff com.apple.MediaKit (12 - 602) <6E429DD7-8829-37DE-94AF-940FB70F2FB9> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
      0x9451b000 - 0x9455fff3 com.apple.framework.CoreWLAN (2.1.3 - 213.1) <8A99ADB8-4A3E-3B8E-A0E4-A39398C288EC> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
      0x94560000 - 0x945b2ffb com.apple.CoreMediaIO (216.0 - 3199.8) <A079E576-64FD-3069-846E-F3B67AF28E15> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
      0x945b3000 - 0x949a7feb com.apple.VideoToolbox (1.0 - 705.94) <8FCC2C08-2D4C-3A96-B57A-CAA56911120F> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
      0x94a36000 - 0x94b47ff7 libJP2.dylib (??? - ???) <3B6A6D1C-5E4D-3814-892A-7C580E063268> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
      0x94b48000 - 0x94b6fff3 com.apple.framework.Apple80211 (7.4.1 - 741.1) <7F29673A-B030-34AF-B8CA-AB30DD63FFAB> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
      0x94b70000 - 0x94b8dfff libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <2870320A-28DA-3B44-9D82-D56E0036F6BB> /usr/lib/libresolv.9.dylib
      0x94b8e000 - 0x94baaff1 libPng.dylib (??? - ???) <F084226B-14F0-36C0-B5EC-22C78406D2B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
      0x958fd000 - 0x95927ff0 libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <5CAA1478-97E0-31EA-8F50-BF09D665DD84> /usr/lib/libpcre.0.dylib
      0x95928000 - 0x95a20ff7 libFontParser.dylib (??? - ???) <71B33EB1-27F8-3C68-B940-FC61A3CFE275> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
      0x95ba6000 - 0x95ba7fff libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
      0x95ba8000 - 0x95babffb com.apple.help (1.3.2 - 42) <DDCEBA10-5CDE-3ED2-A52F-5CD5A0632CA2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
      0x95bac000 - 0x95badffd libCVMSPluginSupport.dylib (??? - ???) <4B0476F9-950D-3EB7-BD83-F65AF0B05F0E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
      0x95bda000 - 0x95ce9ff7 com.apple.DesktopServices (1.6.5 - 1.6.5) <CEC069D7-37A3-3D25-A3BB-39DE99FDA46E> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
      0x95d57000 - 0x95d5bff7 com.apple.OpenDirectory (10.7 - 146) <4986A382-8FEF-3392-8CE9-CF6A5EE4E365> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
      0x95da8000 - 0x95ddeff4 com.apple.LDAPFramework (3.2 - 120.2) <CCEB43CD-3861-33CC-8D9B-588F415A7028> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
      0x95ddf000 - 0x95de0ff7 libquarantine.dylib (36.7.0 - compatibility 1.0.0) <46980EC2-149D-3CF7-B29A-401FB89C275D> /usr/lib/system/libquarantine.dylib
      0x95de1000 - 0x95df1fff libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <D6F728DA-990A-32A3-86FA-4A3F4D88E309> /usr/lib/libsasl2.2.dylib
      0x95e00000 - 0x95e97ff3 com.apple.securityfoundation (5.0 - 55116) <EB53CEF7-4836-39FD-B012-6BC122ED4CE9> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
      0x95e98000 - 0x95ea6ff7 com.apple.AppleFSCompression (37 - 1.0) <5D91F412-7B04-335D-8E1A-AFD463859EA2> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
      0x95ea7000 - 0x95ea7fff com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
      0x95ea8000 - 0x9693dff6 com.apple.AppKit (6.7.5 - 1138.51) <B9D3DCA0-9765-354E-9730-75A45A97DDFD> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x9693e000 - 0x96db3ff7 FaceCoreLight (1.4.7 - compatibility 1.0.0) <3E2BF587-5168-3FC5-9D8D-183A9C7C1DED> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
      0x96db4000 - 0x96e84ffb com.apple.ImageIO.framework (3.1.2 - 3.1.2) <C3CB142F-BE91-3AFA-B052-409F776C0B9E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
      0x96e85000 - 0x96ed8ff3 com.apple.ImageCaptureCore (3.1.0 - 3.1.0) <F7ACE42B-2F58-3642-9469-9CDCF31F0273> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
      0x96f48000 - 0x96f90ff7 com.apple.SystemConfiguration (1.11.3 - 1.11) <68B92FEA-F754-3E7E-B5E6-D512E26144E7> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
      0x96f91000 - 0x96fd2ff9 libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <9FD420FB-7984-3A07-8914-BB19E687D38B> /usr/lib/libcurl.4.dylib
      0x96fd3000 - 0x96ff5ffe com.apple.framework.familycontrols (3.0 - 300) <6735D7ED-7053-3AB8-B144-E7F70A124CCD> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
      0x97892000 - 0x97a46ff3 libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <4AFF6FC3-6283-3934-8EFC-CA227CA11164> /usr/lib/libicucore.A.dylib
      0x97a47000 - 0x97d51ff3 com.apple.Foundation (6.7.2 - 833.25) <4C52ED74-A1FD-3087-A2E1-035AB3CF9610> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x97d52000 - 0x97dc1fff com.apple.Heimdal (2.2 - 2.0) <8ACC5067-441D-31C2-ACBD-4527C1AD73EF> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
      0x97dd6000 - 0x97dd9ff7 libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
      0x97dda000 - 0x97de7fff com.apple.HelpData (2.1.2 - 72.2) <330C6B7F-2512-37B7-B2FF-24E1804E9426> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
      0x97de8000 - 0x97decffd IOSurface (??? - ???) <EDDBEE65-1EB8-33A7-9972-E361A3508234> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
      0x97ded000 - 0x97e04ff8 com.apple.CoreMediaAuthoring (2.0 - 891) <69D569FD-670C-3BD0-94BF-7A8954AA2953> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
      0x97e14000 - 0x97e14fff libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <7EFAD88C-AFBC-3D48-BE14-60B8EACC68D7> /usr/lib/system/libdnsinfo.dylib
      0x97e15000 - 0x97e18ffd libCoreVMClient.dylib (??? - ???) <B8F8916D-F12A-3D95-ABF3-999D57B7D581> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
      0x97e19000 - 0x97e1ffff libGFXShared.dylib (??? - ???) <9C9834EB-B794-38C8-9B90-31D8CB234F86> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
      0x97e20000 - 0x97e35ff7 com.apple.ImageCapture (7.1.0 - 7.1.0) <E5FCA336-7E47-343E-A82D-CCCA5BCD5929> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
      0x97e36000 - 0x97e44fff libdispatch.dylib (187.10.0 - compatibility 1.0.0) <1B857064-288D-3919-B81A-38E9F4D19B54> /usr/lib/system/libdispatch.dylib
      0x97e45000 - 0x97ea0ff3 com.apple.Symbolication (1.3 - 91) <4D12D2EC-5010-3958-A205-9A67E972C76A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
      0x97ea1000 - 0x97ea2ff7 libsystem_sandbox.dylib (??? - ???) <036370E2-9D3E-38B8-B3A5-9056C57E780E> /usr/lib/system/libsystem_sandbox.dylib
      0x97efd000 - 0x97efeff4 libremovefile.dylib (21.1.0 - compatibility 1.0.0) <6DE3FDC7-0BE0-3791-B6F5-C15422A8AFB8> /usr/lib/system/libremovefile.dylib
      0x97eff000 - 0x97f9bfff com.apple.ink.framework (10.7.5 - 113) <05CAFB64-D3B8-3973-87EA-CB8BBE580F6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
      0x97f9c000 - 0x97f9cff2 com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
      0x9807a000 - 0x9816aff1 libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
      0x981e8000 - 0x9833efff com.apple.audio.toolbox.AudioToolbox (1.7.3 - 1.7.3) <F09C7075-2C4E-3A4F-A372-95D700125513> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
      0x984f4000 - 0x98537ffd libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <4BA1F5F1-F0A2-3FEB-BB62-F514DCBB3725> /usr/lib/system/libcommonCrypto.dylib
      0x9855e000 - 0x9856cfff com.apple.opengl (1.8.1 - 1.8.1) <766AFB12-A2CB-3A55-B662-FC9FFCAE0008> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
      0x9856d000 - 0x98574ffd com.apple.NetFS (4.0 - 4.0) <D0D59145-D211-3E7C-9062-35A2833FA99B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
      0x988f5000 - 0x9895dff3 com.apple.ISSupport (1.9.8 - 56) <963339C2-020F-337E-AFB9-176090F818EC> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
      0x9895e000 - 0x98a41ff7 libcrypto.0.9.8.dylib (49.1.0 - compatibility 0.9.8) <819B5833-97F6-3827-8CAE-2F7CA91F0A0D> /usr/lib/libcrypto.0.9.8.dylib
      0x98ace000 - 0x98d53fe3 com.apple.QuickTime (7.7.1 - 2348) <DAA61DE5-ED45-3AAE-8030-351D2C636FF2> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
      0x98d54000 - 0x98d65fff libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
      0x98d71000 - 0x98d7cffc com.apple.bsd.ServiceManagement (2.0 - 2.0) <03F672A7-1463-3C01-8E12-5837F820D12B> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
      0x98d88000 - 0x98d88fff com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
      0x98d89000 - 0x98d89ff0 com.apple.ApplicationServices (41 - 41) <BED33E1D-C95C-3654-9A3A-0CB3607F9F10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
      0x98db1000 - 0x99063ff7 com.apple.AddressBook.framework (6.1.3 - 1091) <B8CC707C-6368-3CDD-BE38-D2335B7CC2DE> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
      0x99064000 - 0x99540ff6 libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
      0x99541000 - 0x9965ffec com.apple.vImage (5.1 - 5.1) <7757F253-B281-3612-89D4-F2B04061CBE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
      0x99660000 - 0x996a2ff7 com.apple.CoreMedia (1.0 - 705.94) <10D5D25F-9BCB-3406-B737-23D9FDF2CC71> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
      0x996b4000 - 0x99961fff com.apple.JavaScriptCore (7534.57 - 7534.57.3) <5AE5C3B8-D807-356B-80D9-4D0A706A10D1> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
      0x99962000 - 0x99988ffb com.apple.quartzfilters (1.7.0 - 1.7.0) <9C8F1F3D-D570-3F5C-9B31-5B5B82161CDE> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
      0x9998d000 - 0x99991ff3 libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
      0x99992000 - 0x9999dfff libkxld.dylib (??? - ???) <14E79D7A-B6C2-35C5-B56D-D343BEC2A106> /usr/lib/system/libkxld.dylib
      0x9999e000 - 0x999e7ff7 libGLU.dylib (??? - ???) <9AF7AD51-16E3-3674-B60E-30EE499D7B46> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
      0x999e8000 - 0x999f5fff libGL.dylib (??? - ???) <A72F14F7-1836-34AB-9F08-67836CB966E4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
      0x99dfd000 - 0x99e06ffb com.apple.aps.framework (2.1 - 2.1) <498C8125-A32E-3554-B4B1-8F416623D45C> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
      0x99e07000 - 0x99ed2fff libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <52421B00-79C8-3727-94DE-62F6820B9C31> /usr/lib/system/libsystem_c.dylib
      0x9a069000 - 0x9a0c6ffb com.apple.htmlrendering (76 - 1.1.4) <743C2943-40BC-36FB-A45C-3421A394F081> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
      0x9a0c7000 - 0x9a0e9ff8 com.apple.PerformanceAnalysis (1.11 - 11) <453463FF-7C42-3526-8C96-A9971EE07154> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
      0x9a0ea000 - 0x9a0efffb com.apple.phonenumbers (1.0 - 47) <84484814-C9BE-33E7-A3DF-4DD0E970B902> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
      0x9a0f0000 - 0x9a0faff0 com.apple.DirectoryService.Framework (10.7 - 146) <59061A4B-D743-3A34-B142-7BE2472BBC2D> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
      0x9a0fb000 - 0x9a10effc com.apple.FileSync.framework (6.0.1 - 502.2) <B79DAE4B-3B1E-32D4-8BEC-F2C034C00B68> /System/Library/PrivateFrameworks/FileSync.framework/Versions/A/FileSync
      0x9a10f000 - 0x9a118ff3 com.apple.CommonAuth (2.2 - 2.0) <6F207851-084B-3354-A1B2-63065BC584F6> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
      0x9a119000 - 0x9a1dcfff com.apple.CoreServices.OSServices (478.50 - 478.50) <916A3B50-1033-3FFE-A9AF-3CC2B0F60EAE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
      0x9a1dd000 - 0x9a20bfe7 libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <30189C33-6ADD-3142-83F3-6114B1FC152E> /usr/lib/libSystem.B.dylib
      0x9a20c000 - 0x9a242ff8 libssl.0.9.8.dylib (49.1.0 - compatibility 0.9.8) <1FB07221-3160-3E55-A8CC-55B4405C8A30> /usr/lib/libssl.0.9.8.dylib
      0x9a243000 - 0x9a2cafff com.apple.print.framework.PrintCore (7.1 - 366.3) <EEC03CAB-7F79-3931-87FE-4DF0B767BF47> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
      0x9a2cb000 - 0x9a2f6fff com.apple.GSS (2.2 - 2.0) <1CB56119-09C5-38FD-8FDC-064E3CC5068B> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
      0x9a2f7000 - 0x9a407fe7 libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <34E1E3CC-7B6A-3B37-8D07-1258D11E16CB> /usr/lib/libsqlite3.dylib
      0x9a483000 - 0x9a483ffe libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
      0x9a484000 - 0x9aeb5fff com.apple.WebCore (7534.57 - 7534.57.7) <5FF60D46-9BC0-3B5A-AFF1-2C965D561009> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
      0x9afdd000 - 0x9b25eff3 com.apple.RawCamera.bundle (4.09 - 711) <F60727D9-0CD4-3315-84F8-1AC2C691751C> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
      0x9b302000 - 0x9b51eff7 com.apple.imageKit (2.1.2 - 1.0) <71FC9A62-4E07-307C-8E6B-4DE7661DC0A3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
      0x9b544000 - 0x9b594ffa libTIFF.dylib (??? - ???) <9511A31E-070C-313E-8320-AAB683AD0653> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
      0x9b595000 - 0x9b5a0ffe libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <4A7FCD28-9C09-3120-980A-BDF6EDFAAC62> /usr/lib/libbz2.1.0.dylib
      0x9b5a1000 - 0x9b5b6fff com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
      0x9b5b7000 - 0x9b5b7fff com.apple.Carbon (153 - 153) <6FF98F0F-2CDE-3888-A304-4ED447D24CE3> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
      0x9b5b8000 - 0x9b69afff com.apple.backup.framework (1.3.5 - 1.3.5) <1FAE91F2-BCEF-387D-B5C4-412C464DA1BE> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
      0x9b69b000 - 0x9b6a3ff5 libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <A1BFC320-616A-30AA-A41E-29D7904FC4C7> /usr/lib/system/libcopyfile.dylib
      0x9b6a4000 - 0x9b6bcfff com.apple.frameworks.preferencepanes (15.0 - 15.0) <A8CE15CF-2539-318A-910C-8789D45FFD69> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
      0x9b6be000 - 0x9b6ceff7 libCRFSuite.dylib (??? - ???) <CE616EF3-756A-355A-95AD-3472A876BEB9> /usr/lib/libCRFSuite.dylib
      0x9b6cf000 - 0x9b6daffc com.apple.NetAuth (1.0 - 3.0) <C07853C0-AF32-3633-9CEF-2480860C12C5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
      0x9b6db000 - 0x9b719fff libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <AF1174F9-4402-31EB-9C84-AB644E5865DF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
      0x9b71a000 - 0x9ba60fff com.apple.MediaToolbox (1.0 - 705.94) <89D37021-C389-3CC5-A158-620ADCBD99EF> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
      0x9ba61000 - 0x9ba6ffff libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
      0x9ba70000 - 0x9bab7ff5 com.apple.opencl (2.0.19 - 2.0.19) <7689E7B9-EE5A-3F74-8699-4CDED9162260> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
      0x9bae4000 - 0x9bb71ff7 com.apple.CoreText (220.22.0 - ???) <EA7210A7-DECC-3F76-8A66-D4E41859B3C6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
      0x9bb72000 - 0x9bb7aff3 liblaunch.dylib (392.39.0 - compatibility 1.0.0) <9E6135FF-C2B1-3BC9-A160-B32D71BFA77C> /usr/lib/system/liblaunch.dylib
      0x9bb7b000 - 0x9bb7cfff libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
      0x9bb7d000 - 0x9bbceff9 com.apple.ScalableUserInterface (1.0 - 1) <C3FA7E40-0213-3ABC-A006-2CB00B6A7EAB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
      0x9bbe0000 - 0x9bbe7fff com.apple.agl (3.2.0 - AGL-3.2.0) <ED5A5B8A-0014-3897-951F-628391333256> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
      0x9bbe8000 - 0x9bbf0ff3 libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
      0x9bbf1000 - 0x9bcc7aab libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <2E272DCA-38A0-3530-BBF4-47AE678D20D4> /usr/lib/libobjc.A.dylib
      0x9bcc8000 - 0x9bcc8fff com.apple.audio.units.AudioUnit (1.7.3 - 1.7.3) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
      0x9bcc9000 - 0x9bcdfffe libxpc.dylib (77.19.0 - compatibility 1.0.0) <0585AA94-F4FD-32C1-B586-22E7184B781A> /usr/lib/system/libxpc.dylib
      0x9bce0000 - 0x9bd32ff7 libFontRegistry.dylib (??? - ???) <C2B84661-A62D-3FFF-8D8C-BC697E9BDF4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
      0x9bd85000 - 0x9bdadff7 libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <AB530FB2-8BD1-3328-95E8-CF449F0429CA> /usr/lib/libxslt.1.dylib
      0x9bdae000 - 0x9bdccff7 libsystem_kernel.dylib (1699.32.7 - compatibility 1.0.0) <79179F83-457A-3539-A76B-E960D2108109> /usr/lib/system/libsystem_kernel.dylib
      0x9bdcd000 - 0x9bdd1fff libGIF.dylib (??? - ???) <2ADFED97-2228-343D-9A53-207CBFDE7984> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
      0x9bdd2000 - 0x9bfa9fe7 com.apple.CoreFoundation (6.7.2 - 635.21) <4D1D2BAF-1332-32DF-A81B-7E79D4F0A6CB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x9bfb7000 - 0x9bfd7ff7 com.apple.RemoteViewServices (1.5 - 44.2) <11C87337-FF29-3976-A230-6387D96563C5> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
      0x9bfe4000 - 0x9c02eff2 com.apple.Suggestions (1.1 - 85.1) <1057087C-AC51-3C3B-BECD-BF97426B2372> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
      0x9c045000 - 0x9c061ff5 com.apple.GenerationalStorage (1.0 - 126.1) <E622F823-7D98-3D13-9C3D-7EA482567394> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
      0x9c062000 - 0x9c0d8fff com.apple.Metadata (10.7.0 - 627.37) <F54AED70-95C5-3561-8C87-D9E5539E98A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
      0x9c0d9000 - 0x9c23bffb com.apple.QuartzCore (1.7 - 270.5) <6D0EC7FC-11E5-35FB-A08A-3B438E89FBDB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
      0x9c23c000 - 0x9c23cfff com.apple.quartzframework (1.5 - 1.5) <EF66BF08-620E-3D11-87D4-35D0B0CD1F6D> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
      0x9c23d000 - 0x9c369ff9 com.apple.CFNetwork (520.5.1 - 520.5.1) <F3C606BF-6DCF-33CD-981B-7253C9E3113A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
      0x9c36a000 - 0x9c3f4ffb com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
      0x9c48f000 - 0x9c498fff libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
      0x9c49e000 - 0x9c519ffb com.apple.ApplicationServices.ATS (317.12.0 - ???) <4D124B65-3D43-32E9-B296-3671347BB888> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
      0x9c51a000 - 0x9c52eff7 com.apple.CFOpenDirectory (10.7 - 144) <665CDF77-F0C9-3AFF-8CF8-64257268B7DD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
      0x9c52f000 - 0x9c532ffc libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
      0x9c533000 - 0x9cbbfff5 com.apple.CoreAUC (6.16.12 - 6.16.12) <9D51400F-B827-3BA7-87F5-954A1CDDAEA9> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
      0x9cbc3000 - 0x9cbe0ff3 com.apple.openscripting (1.3.3 - ???) <0579A4CB-FD6F-3D7F-A17B-AC0F2CF11FC7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
      0x9cbe1000 - 0x9cd44fff com.apple.QTKit (7.7.1 - 2348) <E3312B31-238A-3021-9D23-9F2FD5F0B57A> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
      0x9cd45000 - 0x9cd47ff7 libdyld.dylib (195.5.0 - compatibility 1.0.0) <637660EA-8D12-3B79-B644-041FEADC9C33> /usr/lib/system/libdyld.dylib
      0x9cd66000 - 0x9cd70ff2 com.apple.audio.SoundManager (3.9.4.1 - 3.9.4.1) <2A089CE8-9760-3F0F-B77D-29A78940EA17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
      0x9cd71000 - 0x9ce59fff libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <1841196F-68B5-309F-8ED1-6714B1DFEC83> /usr/lib/libxml2.2.dylib
      0x9ce5a000 - 0x9ce5bff0 libunc.dylib (24.0.0 - compatibility 1.0.0) <BCD277D0-4271-3E96-A4A2-85669DBEE2E2> /usr/lib/system/libunc.dylib
      0x9ce62000 - 0x9ce95fef libtidy.A.dylib (??? - ???) <E962D8EC-6B9D-35B7-B586-F07D92302ADD> /usr/lib/libtidy.A.dylib
      0x9ce96000 - 0x9cef7ffb com.apple.audio.CoreAudio (4.0.3 - 4.0.3) <7A14BE52-6789-3CE3-9AE9-B733F4903EB1> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
      0x9cef8000 - 0x9cef9fff com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
      External Modification Summary:
      Calls made by other processes targeting this process:
      task_for_pid: 15
      thread_create: 0
      thread_set_state: 0
      Calls made by this process:
      task_for_pid: 0
      thread_create: 0
      thread_set_state: 0
      Calls made by all processes on this machine:
      task_for_pid: 911
      thread_create: 0
      thread_set_state: 0
      VM Region Summary:
      ReadOnly portion of Libraries: Total=273.9M resident=158.4M(58%) swapped_out_or_unallocated=115.5M(42%)
      Writable regions: Total=478.7M written=163.2M(34%) resident=290.3M(61%) swapped_out=0K(0%) unallocated=188.4M(39%)
      REGION TYPE VIRTUAL
      ATS (font support) 32.0M
      ATS (font support) (reserved) 4K reserved VM address space (unallocated)
      CG backing stores 16.0M
      CG image 41.2M
      CG raster data 636K
      CG shared images 3416K
      CoreGraphics 8K
      CoreServices 2348K
      IOKit 32.9M
      IOKit (reserved) 12.5M reserved VM address space (unallocated)
      JS JIT generated code 16K
      JS VM register file (reserved) 4096K reserved VM address space (unallocated)
      JS garbage collector 16K
      MALLOC 297.2M
      MALLOC guard page 64K
      Memory tag=240 4K
      Memory tag=242 12K
      Memory tag=243 4K
      Memory tag=249 156K
      OpenCL 68K
      SBRK 4096K
      SQLite page cache 288K
      Stack 72.2M
      Stack (reserved) 516K reserved VM address space (unallocated)
      VM_ALLOCATE 18.4M
      __CI_BITMAP 80K
      __DATA 15.0M
      __DATA/__OBJC 256K
      __IMAGE 528K
      __IMPORT 128K
      __LINKEDIT 63.6M
      __OBJC 3316K
      __OBJC/__DATA 56K
      __PAGEZERO 4K
      __TEXT 210.3M
      __UNICODE 544K
      mapped file 107.1M
      shared memory 12.6M
      shared pmap 6236K
      TOTAL 957.2M
      TOTAL, minus reserved VM space 940.1M
      Model: MacBookPro8,3, BootROM MBP81.0047.B27, 4 processors, Intel Core i7, 2.2 GHz, 4 GB, SMC 1.70f6
      Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 1024 MB
      Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 384 MB
      Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
      Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.198.19.22)
      Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
      Network Service: AirPort, AirPort, en1
      Serial ATA Device: TOSHIBA MK7559GSXF, 750.16 GB
      Serial ATA Device: MATSHITADVD-R UJ-898
      USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfa100000 / 3
      USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0245, 0xfa120000 / 5
      USB Device: BRCM2070 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 4
      USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821a, 0xfa113000 / 8
      USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0xfa200000 / 2
      USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfd100000 / 2
      USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
