    Drawing skis on sketchup
    9 Posts 4 Posters 898 Views 4 Watching
    • Y Offline
      YackMalade
      Hi!
      I'm Allan living in switzerland and I build homemade skis. I use sketchup to draw the shape of my skis but I just don't manage to give them the volume I want and to give them the camber the should have....
      -You know the tip/ tail are thicker than the center of the ski... How can I manage to do that?
      • Let's say we find a solution to the first point... Now I would like to give the camber to this plane ski.... How should I process?
      Thanks you for your tips!
      Allan
      EDIT:
      Like you said, with a picture it will be easier to describe What I want
      http://hostimage.webjapt.com/images/skioutlien.jpg
      • ely862meE Offline
        ely862me
        A few pictures would make it justice.
        You can draw the side profile, then push&pull it . Then draw the top profile and intersect it with the shape you previously created .
        Elisei (sketchupper)
        Come and See EliseiDesign
        • gillesG Offline
          gilles
          Model the same way you built, it will be obvious.
          • ely862meE Offline
            ely862me
            πŸ‘
            Create the normal flat board then use Shape bender to create the camber !
            • soloS Offline
              solo
              Post that model and I'm sure you will get help.
              http://www.solos-art.com
              • Y Offline
                YackMalade
                here is the link to download the file https://docs.google.com/file/d/0B7BHqjqFmUWBWlJUVWl4NFJTZHc/edit?usp=sharing
                • soloS Offline
                  solo
                  As a person that has no clue, the profile is the z shape, the outline is what? and the camber is the x y shape?
                  Am I wrong here?
                  • ely862meE Offline
                    ely862me
                    The camber is the curvature of the side profile, the core is the longitudinal middle section and the outline is the top profile.
                    As I said in my first posts. Intersect the profiles and run shape bender.
                    Skis 1.skp
                    • Y Offline
                      YackMalade
                      It's exactly what I what to do! You were right with your first answer... I tried it but I made a mystake and it didn't work but now with your picture I can correct it!
                      I would like to thank all of you!
