Origami
How do I give thicknesses to inclined faces, as if they are made of metal? Maintaining the correct junctions...
You could try Joint Push&Pull http://sketchucation.com/resources/pluginstore?pln=JointPushPull . Some extra tweaking would be required after running the script.
thanks elisei! joint push pull is ok!
