    πŸ›£οΈ Road Profile Builder | Generate roads, curbs and pavements easily Download
    SketchUp and OSX Mavericks....
    83 Posts 22 Posters 11.8k Views 22 Watching
      slbaumgartner
      @tig said:
      The first report I got was yesterday: it is from the SketchThis toolset and site-page component_load tool...
      I just installed the SketchThis toolset and clicked their tool links. They are sometimes very slow (looks like a blank page), but I got to their site. Have they already rewritten this?
      • E Offline
        ericschimel
        Nope, we haven't re-written anything. As TIG says, it works fine on the PC, and the Mac pre Mavericks. For some reason it just won't work on Mavericks. TIG developed the Ruby for me, and I have web developers that built the website portion of that, as I said, we haven't changed anything.
        I just downloaded the trial of Keyframe animation from the Extension warehouse, and it has the EXACT same issue on Mavericks that my plugin has. Watch the Ruby console and you'll see the same error that my plugin has when you try to hit "Insert into model"
        It would appear that this problem isn't just limited to my plugin, so there are potentially a fair number of plugins out there that could be broken.
        While I'm not much of a programmer, (that's why I've got TIG!) I am pretty good with testing things and using debug tools, so if there is anything I can help the community out with, I am more than happy to do that.
        If it's any help, here's a video of me trying to see if it was a web traffic issue:
        https://www.dropbox.com/s/8l4yt6bswy22b80/Mavericks%20SketchThis%20Bug.mov
        And here's a screenshot of the ruby console error from my plugin:
        http://note.io/1a5H9F5
        And here's a screenshot of the same error in Keyframe animation:
        http://note.io/1gNdwlo
        Again, if there is anything I can do to help out, please let me know.
        -Eric
        http://plugin.sketchthis.net
        Sketchup Kitchen Design Plugin
        Custom Models
          slbaumgartner
          Aha, that's the difference! The prior info didn't lead me to understand that the error is on "Insert into model". When I do that, I get the same error. Unfortunately, since the plugin is scrambled ruby I can't actually debug it.
          Mavericks includes a new version of the WebKit library (I just checked), so they must have changed/broken something that impacts the way that the skp: protocol is spliced in.
            martychristoffel
            I'm running into palettes that are no longer "sticky" since upgrading to Mavericks. To be more precise, although the palettes do snap to one another, when expanding one such as the Layers palette, it opens underneath the minimized Styles, Scenes, etc. instead of having those palettes remain connected to the Layers pane. When minimizing them down to their title bars, they can also lose their relative association to other palettes.
              slbaumgartner
              There must be something more going on in this Tool than I am privy to. I wrote a little test ruby and html page that uses <a href=skp:callback...> to generate a callback to Ruby, and I get the parameter string as usual, without error, including when it is the exact URL in your page. I do not get the skp:callback@http://... stuff reported by the error message. Also, I found that error message string in the WebDialog code, so I think it is thrown back at Ruby from WebDialog when the Ruby code does something to try to load the skp into the model.
              TIG, I think this is back in your court, since the Ruby is scrambled.
                I too have written some simple href="skp:callbackname@string" examples, which I thought might break Mavericks.
                They didn't. πŸ˜’
                Then I rewrote the SketchThis code so that it puts into the Ruby Console the string that is received from the 'install' click href=... callback.
                Surprisingly it never gets to this point, instead it just presents the "Runtime error: invalid URL 'skp.callbackname@http_url_path.skp'", then stops - never displaying the string as it never gets a valid callback returned.
                This is plain weird...
                  Aerilius
                  Did you try variations on how the webdialog's html is created or loaded?
                  In the Trimble/Google forum, someone suggested it's due to set_url(); which would make sense if the Maverick's security model has been further restricted.
                    But my own test-rb+html , the SketchUcation Plugin Store AND SketchThis all use set_url()
                    Only SketchThis fails with Mavericks.
                    It uses:
                    href="skp:callbackname@http://url.skp"
                    Which was the initial 'suspect', since the SketchUcation Plugin Store is reported as working OK and that uses onClick and js function with the equivalent of:
                    window.location="skp:callbackname@http://url.skp"
                    However my tests include various permutations of 'clicking' to callback - i.e. href=... and window.location=... etc - and ALL of those work on Mavericks, and return the passed string correctly, whereas the very similar looking html code href=... for SketchThis fails with the 'invalid URL' message in the Ruby Console ???
                      slbaumgartner
                      It uses:
                      Weird indeed!
                      Our attempts at test cases don't produce the error, so we must be overlooking something subtle about the exact way that the SketchThis page is constructed. I tried the exact URL from their page in my callback test, and it worked fine. So it isn't the address. It has to be something about how it is set up on that page. But what???
                        slbaumgartner
                        They didn't. πŸ˜’
                        So, WebDialog is throwing this exception before it ever passes the callback to your Ruby. The Foundation library must have identified the skp: "scheme" correctly, else it would never have handed this request to the WebDialog's protocol handler. But for some reason either it or WebDialog is failing to extract the correct path out of the request. I remain baffled why we can't reproduce this in simple test cases. That's especially frustrating because if we can't identify a causing pattern, we can't recommend a viable workaround.
                        Pulling at any thread I can find: this page makes use of jQuery to do things such as track usage. Could this be somehow entangled? Just as a theory, could Mavericks have changed something in the javascript engine that causes this bug and we aren't reproducing it because we aren't firing the same javascript enroute to Ruby? Seems like a long shot, but when in desperation...
                          Jquery might be a factor - my test didn't include it...
                          Presumably the page records downloads using it ??
                          When you read the SketchThis html source it has <a href="skp:callbackname@http://urlpath.skp"> etc.
                          When I test it... it works... except on MACs with Mavericks, when it fails...
                          When I do the exact same code on my TIG.this test it always works !
                          The only difference is my html has:
                          <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html>
                          BUT the SketchThis html source has:
                          <!DOCTYPE html> <!--[if IE 6]> <html id="ie6" lang="en-US"> <![endif]--> <!--[if IE 7]> <html id="ie7" lang="en-US"> <![endif]--> <!--[if IE 8]> <html id="ie8" lang="en-US"> <![endif]--> <!--[if !(IE 6) | !(IE 7) | !(IE 8) ]><!--> <html lang="en-US"> <!--<![endif]-->
                          I haven't managed to retest with that in my code, as I am currently downloading/installing Mavericks on that MAC...
                            slbaumgartner
                            I tried that DOCTYPE and conditional stuff. No effect - my test code still gets the right URL. The Jquery stuff is way more complex than I feel competent to fiddle with...haven't used it enough.
                              driven
                              from web inspector inside SU the source for this item reads
                              <a href="skp;add_component@http://plugin.sketchthis.net/wp-content/uploads/2012/07/Sizeable-Back-Panel.skp" class="btn all">Insert into Model</a>
                              does that work in tests??
                              EDIT: re-read the thread and see it does...
                              observation, if you just paste the address into Safari it downloads the file to 'Downloads', and you get a 'saved in v8' warning when you open that skp. Maybe the warning is blocking it being automated?
                              john
                                slbaumgartner
                                @driven said:
                                john
                                Nope - I am running 8 and get the same error there.
                                Steve
                                  @John
                                  That's the path: I just wrote a 'shorthand' form πŸ˜‰
                                  I have tested it my own rb/html with the exact same href= text and it works fine with Mavericks too πŸ˜’
                                  Perhaps it's something to do with some remote url's and permissions ? πŸ˜•
                                  The SketchUcation Plugin Store uses some similar [onClick=] callbacks and they all work in Mavericks as far as I know 😲
                                  • H Offline
                                    honkinberry
                                    Everything totally broken here.
                                    Tried changing the Doctype around, from Transitional to Strict to Html 5, all no change.
                                    Tried href= vs window.location= vs document.location=, all broken, broken, broken.
                                    If TIG or anyone has sample code that does work within Mavericks, I'd love to see it.
                                    Most of our skp: callbacks are within Javascript for ease of maintenance. Usually fired by onclicks, but it can vary.
                                    --J
                                      At the moment I am at a loss...
                                      Some methods work in Mavericks, some do not [both href= and onClick= + window.location=].
                                      BUT some that fail in one html document, will work in another, when the code looks all but identical πŸ˜•
                                      I can see not commonality for the fails/successes... 😲
                                      Waiting for Trimble's engineer's feedback....... πŸ˜’
                                      • H Offline
                                        honkinberry
                                        Here's a little more info from testing if this helps.
                                        I have two dialogs which are identical, both just a Select listbox, with an OnChange event that fires a window.location callback. Using Transitional doctype.
                                        The one that is a local htm file stored in the Plugins folder, that works.
                                        The one that is remote PHP, that one fails.
                                        --J
                                        • Chris FullmerC Offline
                                          I've got nothing to add at this point, but I did want to chime in just to make sure everyone knows that we are looking into this issue as best we can also and working directly with some of the developers who have emailed us already. We'll post here as soon as we know anything useful. Thanks,
                                          Chris
                                          All my Plugins I've written
                                          • E Offline
                                            ericschimel
                                            Thanks Chris, so I may have something helpful, just bear with me because I am not a programmer...
                                            TIG is the guy who writes my plugin (and he does a fantastic job)
                                            I was talking with a friend of mine who's a software developer and he wanted to take a crack at solving the problem, and while he didn't get it, he thinks he may have something that will shed some light on the subject. Again, please bear with my elementary description:
                                            My plugin downloads content from the web, Sketchup files to be exact. Since the Mavericks update, it's broken.
                                            TIG had written a small plugin that could test the way links were formed in Mavericks. My friend took that plugin and tried testing a local VS remote web page.
                                            So what we proved (I think) is that a link is properly passed to Sketchup when the page is saved on the local machine (in the plugins folder) but when the link is to a page that is remote (on the web) it fails.
                                            So while that's not an answer, it appears Mavericks is blocking this somehow. The attached test code proves this. Take a look at the Ruby code, and you can fire up a local or remote test by typing in "TIG.local" or "TIG.remote" into the Ruby console.
                                            I have the remote page in the code hosted on a public Dropbox folder (with a proper public link) and I will leave it there for testing.
                                            https://www.dropbox.com/s/gprwg3lolzxnp39/TIG%20This%20Test.zip
                                            I hope this somehow helps.... (And that I've explained it properly)
                                            -Eric
                                            Custom Models
                                            • 2 / 5
