    Check if component exists before making it
    6 Posts 2 Posters 478 Views 2 Watching
      MCorgano
      I have a script that rasterizes a line into cubes. My problem is, I want to make sure it doesn't generate duplicate cubes. How do I do that?
      require 'sketchup.rb'
      require 'extensions.rb'
      cCube = Sketchup.active_model.definitions.add("Cube") ;
      newface = cCube.entities.add_face( [ [0.5, -0.5, 0.5], [0.5, -0.5, -0.5], [-0.5, -0.5, -0.5], [-0.5, -0.5, 0.5] ] ) ;
      newface.reverse! if newface.normal.z < 0 ;
      newface.pushpull(1) ; # extrude it up to make a cube
      Sketchup.active_model.selection.each { |entity|
      	x = entity.start.position.x
      	y = entity.start.position.y
      	z = entity.start.position.z
      	l = entity.length
      	dx = (x-entity.end.position.x)/l
      	dy = (y-entity.end.position.y)/l
      	dz = (z-entity.end.position.z)/l
      	for i in 0..l.to_int
      		cx = (x - (dx*i)).round
      		cy = (y - (dy*i)).round
      		cz = (z - (dz*i)).round
      		# a bit of code to make sure a cCube doesnt exist here already
      		Sketchup.active_model.active_entities.add_instance(cCube, Geom;;Transformation.new([cx,cy,cz]))
        name="Cube" name=Sketchup.active_model.definitions.unique_name(name)
        if 'Cube' is already taken it becomes 'Cube#1'
        if 'Cube#1' is already taken it becomes 'Cube#2' etc...
        Sketchup.active_model.definitions.add(name)
          MCorgano
          That solves a different question I had (lol) but not the one I'm asking here.
          Let's take point [1, 2, 3]. I want to add an instance of cCube at that point
          Sketchup.active_model.active_entities.add_instance(cCube, Geom::Transformation.new( [1, 2, 3] ))
          What I want to know, is how do I check that that instance of cCube does not already exist?
          How do I prevent creating duplicate instances of a component?
          If there is not a cCube at [1, 2, 3] then{ Sketchup.active_model.active_entities.add_instance(cCube, Geom::Transformation.new( [1, 2, 3] )) }
            point=Geom;;Point3d.new(1,2,3
            )### or whatever 'point' you are testing for
            exists=false
            compo=Sketchup.active_model.definitions['Cube']
            compo.instances.each{|ins|
              if ins.transformation.origin==point
                exists=true
                break
            if exists
              puts 'That Cube exists already!'
            else
              ### do your stuff to add a new instance of compo at point
              Sketchup.active_model.active_entities.add_instance(cCube, Geom;;Transformation.new( [1, 2, 3] )
              MCorgano
              > exists=false
              >     exists=true
              >     break
              >   end
              > if exists
              > else
              > end
              How will this effect performance if I had hundreds of them? I figured something like this must be possible, but as the number of cubes grows, this would become less efficient. I'm talking on the scale of ~2000 cubes. Is this method efficient enough for the speed to be negligible?
                At best it will find a match immediately 1/2000, at worst at go 2000/2000, on average at go 1000/2000.
                You can but test it and see...
                If you are adding all cube-instances in the same SketchUp session then why not make a @points array to push [ <<] all of the points you will use during the placements - these need to be as arrays so they are 'comparable' [use point.to_a] - points are comparable as == but include? is faster [most probably] with array comparisons ?
                Then... instead of finding all instances and comparing each 'instance.origin' to 'point' use:
                @points.include?(point.to_a)
                If the tested point is in the current list then it's taken and you skip the operation...
                Of course this doesn't work when instances have been erased or across SketchUp sessions πŸ˜•
