    Pattern fill and scrapbook missing
    layout
    3 Posts 2 Posters 1.8k Views 2 Watching
    • E Offline
      Elpiapo
      I have SU13 on Mac. Somehow the pattern fills and stand scrapbook in layout are missing. I have my custom scrapbook but that's all and nothing in patterns fill. How do I refresh this items?
        marcdurant
        Hi-
        Sounds like the LayOut folder preferences aren't set correctly.
        Warning! The following procedure will cause LayOut to forget your custom scrapbook location - after doing this, you'll need to add the custom scrapbook folder again.
        The easiest way to check these paths is to run LayOut, go into the LayOut->Preferences menu, and choose the "Folders" page. Press the "Reset to defaults" button for each section (Templates, Scrapbook, and Pattern Fills) to make sure that the paths are set correctly. After resetting to defaults, you'll need to add your custom scrapbook folder again.
        If this doesn't fix your problem you may need to reinstall.
        thanks,
        Marc
        • E Offline
          Elpiapo
          Thanks for your help! I did just as you suggested with success. My custom scrapbook remained too! Again thanks...
