    Load text file and assign to variables
    7 Posts 2 Posters 1.1k Views 2 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi,
      when i reopen my text-file with parameters (1 parameter per line)
      by
      count = 0
      File.open('C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/zf/partemp2.txt', 'r') do |f1|
      while line = f1.gets
      puts line
      i can see the values listed in the console // OK
      BUT
      when i try
      count = 0
      puts line
      value[count]=f1.gets
            count = count + 1
      it does not work
      ma question is:
      how can i assign the result of f1.gets to a row of variables in this loop?
      thanx you
      stan
        I think perhaps an easier format to think about would be:
        file = 'C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/zf/partemp2.txt'
        IO.readlines(file).each_with_index{|line, i|
          line.chomp! ### removes the '\n' from the end of the line
          next if line.empty? ### this traps for empty lines
          next if line =~ /^[#]/ ### lines starting with e.g. '#' are ignored; allows for headers/comments/disabling
          puts i
          puts line
          ### or more likely do your stuff using the string 'line'
        Note: if you don't need the index 'i', then use ' ).each{|line|' instead...
          artmusicstudio
          hi tig and hello again,
          this is great and worked inmedialtely in the ruby console.
          so:
          i counts the lines
          line gets the value per line
          maybe a small tip (i still think too much in macro-basic)
          when i retrieve those values form the file,
          this syntax makes problems:
          assign variables from file (like reading an array from a loop)
          a = line[1]
          b = line[2]
          c = line[3]
          how could i build an array within the import routine? i tried so many ways and can#t get it...
          thanx stan
                lines=[]
                IO.readlines(file).each{|line|
                  lines << line
            NOT sure why you need separate variables... this makes an array of the lines called 'lines'
            Now lines[0] is the first line, lines[1] is the second line etc [note how an array index starts at 0 not 1 !]
            To find the last line use lines[-1] etc...
            So you have reference to each lines using this method, without extra variables...
            If you really want to set up a series of variables then you can do it thus...
            ### you need to set up instance variables, @v_a etc, so they get referenced outside of the {} block, plain v_a won't be referenced outside and would therefore be inaccessible...
            v='@v_a'
            lines.each{|e|
              eval("#{v}='#{e}'")
              v.next!
            Now @v_a will return lines[0], @v_b gives lines[1] etc... BUT as I said sticking with lines[0], lines[1] etc seems far simpler and easier to use/control... πŸ˜’
              artmusicstudio
              hi tig,
              thanx a lot, i inserted the new import routine and tried different variantion.
              ruby gives back:
              load '01.rb'
              true
              Error: #<NameError: undefined local variable or method lines' for #<Object:0x3d31654 @v_b="90", @v_a="300", @v_c="100">> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:96:in draw_stairs'
              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:48
              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:96:in call' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:96 load '01.rb' true Error: #<NoMethodError: undefined method /' for "300":String>
              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:173:in draw_stairs' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:48 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/01.rb:96:in call'
              so the situation is:
              i am created an object in skp, which can be controlled in diverse dimension by an input menue (parameters)
              when the object is created, i save the parameters in a text file (parttemp2.txt):
              content of parttemp2.txt now for testing:
              300
              90
              100
              it seems, that reloading these numbers gives back STRINGS and not numbers
              as <ou also said, i would like to handle these imported parameters by
              parameter01 = lines[0]
              parameter02 = lines[1]
              and so on.
              but it simply does not work now for me. have to study more about formats (you know, i am on ruby since few days)
              this is the whole pert of the code: (where WIDTH shall become the value of line 0 in the text-file)
              require 'sketchup.rb'
              #require 'offset.rb'
              #require 'makesoftsmooth.rb'
              Sketchup.send_action "showRubyPanel:"
              #Add a menu item to launch our plugin.
              UI.menu("PlugIns").add_item("01-ZF-Stairs"){
              UI.messagebox("Outdoor-Stairs - Script - 131011-V 0.1j - Zdenek Fajfrlik")
              #result = UI.messagebox "New Definition?", MB_YESNO
              #if result == 6 # Yes
              UI.messagebox("New Definition")
              #count = 0
              #File.open('C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/zf/partemp.txt', 'r') do |f1|
              #while line = f1.gets
              #puts line
              #width = f1.gets
              #end
              #end
              file = 'C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/zf/partemp2.txt'
              lines=[]
              lines << line
              v='@v_a'
              lines.each{|e|
              eval("#{v}='#{e}'")
              v.next!
              Call
              draw_object
              def draw_object
              #delete previous model
              model = Sketchup.active_model
              entities = model.active_entities
              entities.to_a.each { | entity| entity.erase! }
              set start default values for MENUE 1-4
              width          =  @v_a
              lwidthplus     =  @v_b
              rwidthplus     =  @v_c
              #width          = 500
              #lwidthplus     = 10
              #rwidthplus     = 10
              stairs         = 10
              run            = 30
              rise           = 13
              thickness      = 3
              fill           = 4
              overlap        = 6
              il             = 6
              rc             = 3
              re             = 0
              stepdevidex    = 1
              sl             = 100
              sr             = 100
              mr             = 80
              pmod           = 3
              pradius        = 15
              thradius       = 20
              mhradius       = 4
              lines          = 4
              ro             = 4
              rol            = 5
              ror            = 5
              wangenbreitel  = 30
              wangenhoehel   = 10
              wangeslopel    = 45.0
              rampoffsetl    = 50
              rampoffsetly   = 30
              rampoffsetlz   = 99.0
              wangenbreiter  = 30
              wangenhoeher   = 10
              wangesloper    = 45.0
              rampoffsetr    = 50
              rampoffsetry   = 30
              rampoffsetrz   = 99.0
              thank you very very much for your time and helping!
              STAN
                Please use the 'code' BBS tags for large blocks of code - it's very hard to read otherwise.
                You do NOT need to assign a whole load of variables with eval...
                Just use ' lines' OR whatever you call it as the array of values...
                To find the first one use lines[0] and so on...
                You cannot pass variables across methods unless you pass them as arguments after the method [def] name OR the methods are in the same module/class and are instance ones - starting with @....
                You are making this far more convoluted than it needs to be...
                Can we go back a few steps...
                What is it you are trying to do exactly - I get part of it so far?
                What is in the file you are reading in exactly [data/units/etc]?
                You are reading in strings, NOT numbers, so convert it to a float using .to_f
                Then you can use / etc on them...
                parameter01 = lines[0].to_f
                BUT if you know they are in cm or mm you need to use say:
                parameter01 = lines[0].to_f.mm
                etc...
                You are getting in a muddle... πŸ˜’
                  artmusicstudio
                  hi tig,
                  that's it .
                  my logic was ok, your tip for the conversion of string to float was the point.
                  basicly it works like this:
                  i have menues for parameters
                  then the geometry is created
                  before the end of the ruby i save all parameters to a text file (by the way still looking for the syntax to save more of them line by line)
                  then the user can recall the ruby and select
                  -my last parameters
                  -defaults
                  and so on and so on
                  again another step!!!!
                  regards stan ( i'll report , when i get further)
