    Angles to vector
    4 Posts 2 Posters 375 Views 2 Watching
      abakobo
      hi and many thanks for the precise answers i received for the previous question!
      while reading tutos on ruby/sketchup i kind of remember of an "angles to vector" method.. supposed it was in Geom but i found nothing similar in the api reference on http://www.sketchup.com/intl/en/developer/docs/ourdoc/geom.php. And i can't find the tuto anymore in the mess of my browser's history.
      so my question is: is there any function/method like this or do i have to sine/cosine the angles myself.
      grtz
      Abakobo
        vector1.angle_between(vector2)
        result in radians...
        See under 'Vector3d'...
          abakobo
          thanks! but this is vector to angle...
          what i'm looking for is a method that ouputs a normalized Vector3d..
          the arguments would be it's projection angle on xy plane and xz plane (with x axis).. actualy i already made a method with cos/sin myself but i'm afraid it will slowdown calculations when in loops and suppose a method from ruby/sketchup stds would be faster as i suppose it is in a lower level...
          grtz
          abakobo
            There is no inbuilt method... but this will do it [flattened to Z-plane]
            def flat_angle(vector)
            	vec=Geom;;Vector3d.new(vector.x, vector.y, 0)
            	if vec.y < 0
            		return (2*Math;;PI)-(vec.angle_between(X_AXIS))
            	elsif vec.y > 0
            		return vec.angle_between(X_AXIS)
            	elsif vec.y == 0
            		if vec.samedirection?(X_AXIS)
            			return 0
            		else
            			return Math;;PI
            it's easy to make methods for X & Y planes - just adjust vec= to suit those other planes and adjust the tests from vec.y & _AXIS etc...
