    Follow me tool pls
    41 Posts 8 Posters 3.2k Views 8 Watching
    • E Offline
      erzane
      I would like to make those pipes more rounder and less angular
      I used the follow me tool but I cannot have a good result
      first I created a line from 1point to another for making a following line to the follow me tool (for help the tool to go to the good direction)
      is it a way to make it ?
      pls see pics
      made with skp
      corrected with PS
      place where pipes should arrive, but I cannot finish them to a precise receiving point
        Follow Me will only follow the path you draw. If you want smoother, rounder bends in the extrusion, draw the path that way.
        • E Offline
          erzane
          I thought about that, but after trying it's very difficult to draw the path smoother, even if I use the free hand tool
          is there some vid/tuto which shows the easiest way to draw smooth and round paths ?
            mwm5053
            Have you tried the arc tool or bezier spline tool (a plugin you will have to install yourself)
            2011 iMac
            SU 2015 Pro, 2017 Make
            V2 Twilight
            macOS Sierra 10.12.5
              It looks like you managed to draw other curves just fine. Maybe you need to use some guidelines to help you layout the path. Or draw a face or faces (a triangle would probably work) onto which you can draw the path. Then delete the edges you don't need.
              The selected edges will be the path.
              After Follow Me
              • BoxB Offline
                Here's another version using just line and arc.
                [screenr:6pagqd1q]LALH[/screenr:6pagqd1q]
                • E Offline
                  erzane
                  both are very good!
                  I'll try that
                  thanks a lot guys
                  I'll give you news soon as I succeed
                  box, which too re you using to make the same as movetool ?
                  is it a special tool ?
                  • BoxB Offline
                    I don't know what you mean, I didn't move anything.
                    Can you try to explain what action you are asking about?
                      Just a guess but I think erzane is referring to orbiting and I expect you are just pressing the center mouse wheel/button to access it. Correct?
                      • BoxB Offline
                        Yep Dave, that's how I was doing it.
                        I didn't want to think it was that, I shudder to think how difficult it would be to use SU without knowing about the scroll wheel orbit/pan/zoom.
                        • E Offline
                          erzane
                          ok I see now
                          because the move too have another looking and I didn't recognised it on the video you made
                          so , that's because you pushed the center button of the mouse right ?
                            Move and Orbit are two very different things. What you see Box doing in the video is orbiting around the model. Move would actually move the model in the model space. Orbit is like walking around the model space looking at the model from different directions. This is a fundamental thing in SketchUp and you really need to understand it to progress.
                            • E Offline
                              erzane
                              do you mean orbiting, the ''O'' key ?
                              if yes I knew it already, but I tought I saw a different designed tool..
                              oh ok I see now, I think you have a different sketchup version than me , that's why follow me tool and orbiting looks different, they have different design, (I use sketchup 8.0)
                              • BoxB Offline
                                Yes, it's orbit and follow me in 2013.
                                It would help if you updated your profile because answers can vary depending on operating system and Sketchup version.
                                  There oughta be a "Like" button.
                                  • BoxB Offline
                                    One little pipe led to another little pipe which led to I got carried away...... 😲
                                    • BoxB Offline
                                      Cheers Dave, perhaps it's a steampunk borg cube.
                                      • JQLJ Offline
                                        JQL
                                        Nah Box! It's a box! And a nice one might I had!
                                        JQL
                                        www.casca.pt
                                        Visit us on facebook!
                                        • E Offline
                                          erzane
                                          here is guys
                                          thanks for your help 😄
                                          • BoxB Offline
                                            Erzane, I'm not sure if you want all the "sections" in your pipes but if you "weld" the path before you use follow me you won't get all those joints.
                                            • 1 / 3
