    Controlling more than X/Y/Z and height/width/depth
    2 Posts 2 Posters 1.1k Views 2 Watching
    • J
      jon bondy
      I have created a set of dynamic components which behave as follows:
      • left and right sides always form semi-circles
      • central section always joins the two semi-circles, taking up whatever space remains
      So far, so good. What I'm finding is that as I scale things, I also want to control the thickness of the three parts, so that larger parts are thicker than smaller parts. Is there any way to do this?
      • P
        pcmoor
        Since you want to create an object that maintains two ends with variable distance between then split into four as you have drawn, the half cylinder ends as per attachment, the trick is to build cutting holes top, bottom and side, hide any lines not needed to be seen (outline of hole), add outlines or faces (e1,e2 you can delete these for your project) as required. See my models on warehouse...cylinder, pcmoor
        the rectangle sides should be no problem, hide the lines at the joins. The position of components can be tricky, but i let you give it ago, let us know if you need further help
        Cheers
        Philip
        half cylinder.skp
