    [Plugin] LSS Zone
    22 Posts 11 Posters 7.9k Views 11 Watching
    • facerF Offline
      facer
      plugin - LSS Zone Used in conjunction with LSS Arch Lite
      Use of LSS Zone for concept sketch design.
      The following comments relate to this use of LSS Zone for concept Sketch Design.
      LSS Zone can be improved for Sketch Design if the drawing of a Zone is similar to drawing walls in LSS Arch Lite.
      At present, it is difficult to determine if a right angle has been drawn in LSS Zone. I like the firm snapping and
      guide symbols used in LSS Arch Lite, these would help in LSS Zone.
      Using LSS Zone in the Sketch Design phase gives the following advantages:
      1. Quick "block modelling" of required rooms or zones
      2. The Client's Brief can be checked quickly in regards floor areas and hence costs (based on $/sq. metre)
      3. The "volume massing study with LSS Zone" allows quick insights to the evolving "shape" which then illustrates likely issues as height (setback requirements) and the sun (shadow)
      Your present focus for LSS Zone is for the analysis of rooms for multi-residential buildings.
      The first time user of LSS Zone is most likely doing smaller scale projects.
      The use of LSS Zone in the Sketch Design phase could be of interest if they were
      alerted to its potential use.
      Regards,
      Ray
      • K Offline
        kirill2008
        Hello Ray,
        I decided to copy my answer in this thread as well. Here is LSS Arch Lite thread where I posted basically the same reply.
        I agree about problems with UI in LSS Zone (lack of direction lock using Shift key while drawing and editing for example etc). I added recently a "Zone" tool to a full version of LSS Arch. It basically uses the same logic for zone object as free LSS Zone extension, but utilizes UI logic of LSS Arch (so zone tool behaves basically the same way as other LSS Arch tools, direction lock is available etc). I tested how zone tool works in LSS Arch during a project, which I'm currently involved in at work, and I'm mostly happy with results (I revealed a couple of minor problems in zone tool inside LSS Arch though so fixing is in progress right now and nearest minor update of LSS Arch will contain those fixes).
        So now I have an idea to publish new commercial LSS Zone Pro extension, which would utilize UI logic of LSS Arch and drop support of a free LSS Zone extension, because I'm afraid I have no ability to continue developing of freeware projects (at least at the moment). Such new extension can be used in combination with LSS Arch Lite (such combination would provide ability to trace quickly closed spaces bounded by walls). I hope this plan will come true someday.
        Sincerely,
        Kirill
        • 2 / 2
