    Find (3d point) intersection of 2 lines?
    2 Posts 2 Posters 647 Views 2 Watching
    • T
      tomot
      I can't find via search if this has been answered before. 😞
      1. 2 lines including each of their end point coordinates are known,
        they also intersect and share a common plane.
      2. The common plane these 2 lines intersect on may be xy, yz or xz planes
      3. Since the end points of each line may change their common intersection point will also change.
      How do I quickly derive the intersecting point, for any varying 2 line intersection?
      TIA!
      my plugins
      tomot
      • TIGT
        Try
        point = Geom.intersect_line_line(edge1.line, edge2.line)
        You either get a point or nil if the two 'lines' don't intersect.
        Unlike an 'edge', a 'line' is infinite, so two 'edges' might not physically intersect even though their 'lines' do.
        If you get a point you can then test if it actually falls on an end point of an edge
        point == edge1.start.position point == edge2.end.position point == edge1.start.position point == edge2.end.position
        where true shows it is at a vertex
        AND if the point falls between the start/end of each edge, the test is...
        point.vector_to(edge1.start.position) == point.vector_to(edge1.end.position) point.vector_to(edge2.start.position) == point.vector_to(edge2.end.position)
        Note that getting true means that the point is not physically on the edge because the vectors are both in the same direction, and false means that the point is on the edge and between the start/end...
