Make Component - Glue to:
It would be nice to see the "Glue to" drop-down list in the Create/Make Component window be more dynamic; something where you can type in the first letter of the option: N - None; A - Any; H - Horizontal; V - Vertical; S - Sloped, instead of always having to manually select the option from the list, or perhaps use radio buttons to select the option instead of a pull-down list.
One other very small suggestion: change either the pop-up window title from "Create Component" to "Make Component" or change the context and Edit pull-down menu to say "Create Component".
Sorry for nit-picking...
Register LoginAdvertisement
