    Export CAD from Layout
    layout
    2 Posts 2 Posters 575 Views 2 Watching
    • S
      Syd_Nsr
      I use SU8 and LO3 to build models that customers need finally as .dwg Drawings.
      I can export layout to 2D CAD but it doesn't go as groups or components as i built. It shows exploded lines
      Any idea how i can work around this problem, such issue can prevent us from using SU for poor quality.
      I tried CADUp plugin, but unfortunately it doesn't help. i tested the plugin that geneartes views per component/group not per model where several components and groups are placed together. in such way i lose advantage of Layout as well (plugin works on SkU only).
      I wonder why neither layout nor SK (2D graphic export) do the right job, export components/groups as .dwg blocks?
      • yorik1984Y
        yorik1984
        what type of drawing?
        I make section cut. Save as component to other file. Then export to DWG this component like model 3D. In result i have flat drawings with blocks includes each other.
