    Zooming issues
    3 Posts 3 Posters 347 Views 3 Watching
    • G
      gcld1000
      Ive never really understood the variations on when you zoom into an intersection and sometimes you can get in really close, other times you zoom "through" the plane and out the other side. Similarly, when you seem to fly through walls from when panning. Is there a setting I have now turned on to make it hard to get in close to the details?
      cheers
      • BoxB
        If it is like a sort of super zoom where a tiny roll of the wheel sends you whizzing through your model, then it is probably your mouse driver. Have you recently bought a new mouse or updated an old mouse software? If I remember correctly there is setting in mouse properties for smooth scroll. Try unticking that.
        If on the other hand your model is disappearing as you zoom in then that is clipping and another issue.
        • S
          smicha
          Switch to parallel projection view (I assigned F5 key to switch between parallel and perspective view). This enables zooming in very close any point, line, plane.
          Hope it helps.
