    [Plugin] Rename by Layer v1.0.3
    51 Posts 18 Posters 27.5k Views 18 Watching
    • bmikeB Offline
      bmike
      @driven said:
      mike
      I think you'll need to edit the plugin yourself...
      I'll see if I have a copy and what line needs the tweak...
      john
      Thanks John. I have done that with most plugins... once someone points me to the code or the line...
      But I'm not at all capable or writing Ruby... so I thought I'd ask.
      -Mike
      mike beganyi design + consulting llc
        driven
        without testing...
        in the menu ruby, you need to change line 63 rnd_renamer_tb.show
        		rnd_renamer_tb.restore
        it should then honour last state...
        john
        • bmikeB Offline
          bmike
          @driven said:
          without testing...
          john
          that worked. thanks....
          also figured out how to change the HTML window size, always bugged me that the content didn't show in the window and i'd have to stretch it to see what i was doing.
            retep37
            Does anyone know if Rename by Layer v1.0.3 works in SketchUp 2015 or SketchUp 2016? I am not familiar with the tool, but tried it in SketchUp 2015 (on Windows) today and although it loaded I could not get it to do anything. Above, somone mentioned SU 2015, but I think on Mac, not sure if the OS would matter.
            PeterB
            • srxS Offline
              srx
              Thank you for this very useful plugin. πŸ‘
              I miss two things to be even better for my workflow. I guess it is not hard to change them for one who knows whats doing...
              1. Is it possible to dig deep to all nested groups - components instead of one level only?
              @renderiza said:
              I am adding the "prefix" & "suffix" feature for the numbers.
              How to make plugin start with this option not selected?
              www.saurus.rs
              • srxS Offline
                srx
                Idea:
                1. As JQL mentioned usual procedure of structuring SU model in a BIM manner is to group several groups-components and put them on layer, say WALL. They stay on layer 0. Good workflow could be to name all Layer 0 groups - components by their material, say "brick" so we have the complete information that it is a brick component of composite wall building element.
                Is it doable?
                Thanks again for great plugin.
                www.saurus.rs
                • P Offline
                  pohlr1
                  I know this is an old forum but I have an addon from smustard that groups by layers. When it does this the new group created does not have an instance name. But the underlying geometry still has its name. I was wondering if there is a script to rename the new groups based on the name of the layer that its geometry is on since all of the groups geometry is on the same layer.
                    AISmebel
                    Hello. Thanks for your plugin. I have been looking for something like that for a long time. I like everything, but there is something I would like to change. I do not need the "#" sign in front of the component name. Tell me how can I fix this? Thank you very much!
                    • nanolinN Offline
                      nanolin
                      Hello . anyone can share me the latest version please , thank
                      • renderizaR Offline
                        renderiza
                        Here is an RBZ of Rename by Layer
                        After installing please restart SketchUp.
                        i3d_renamer.rbz
                        This is a very old plugin so I modified the code a bit, but it still needs a mayor update.
                        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                        • nanolinN Offline
                          nanolin
                          @renderiza said:
                          [attachment=0:1hc7teg6]<!-- ia0 -->i3d_renamer.rbz<!-- ia0 -->[/attachment:1hc7teg6]
                          Thanks , you saved my life
                          • 3 / 3
