    Make unique texture for every face selected
    3 Posts 2 Posters 423 Views 2 Watching
    • N Offline
      noldo
      It would be useful to have the possibility of applying a texture to a group or component, and then activate a function that makes each texture applied to a face, a unique texture.
      This would allow you to use an external program to bakerizing such as global illumination.
      To do this, however, it would also be necessary that the texture created as unique texture, were linked and not incorporated in the drawing in sketchup, in order to modify the texture only externally, without touching the model.
      Some might suggest the possibility of exporting the model, bakerizing textures and re-import the model, but in doing so you lose in precision, for this would be useful to intervene only on the texture.
        Aerilius
        You can make each single face unique using this plugin: http://www.sketchucation.com/forums/viewtopic.php?f=323&t=41441&p=466990
        • N Offline
          noldo
          Thanks Aerilius.
