    How to make this form
    4 Posts 2 Posters 375 Views 2 Watching
    • I Offline
      imabzeous
      Hello all. can any body help me that how can i achieve this shape. i have tried it and made it by extrude edges by lattice and also made the face by extrude edges by face and applied lattice maker.. but it wont help me. i am attaching the two image.. the one i made with EEBL it is like horizontal grid and i want a diagonal grid and the inner shape can be anything square circle, triangle like in EEBL ( circles would be great )...
      following are the attached images..
      one is 3d that i made and the other is sketch thats how i wanted the form please help me.
      If you can see the shape i made had both diagonal and horizontal lines but i want the diagonal line on both side and not like this.
        Make your form without hole and with a little tchickness wanted
        Then insert little cylinder any where you want with diameter wanted
        Then Intersect them with the form if you have no Pro version
        else boolean Diff operation
        • I Offline
          imabzeous
          i have pro version and what is bolean diff operation? and thank you so so much. never thought of this actualyy 😞
            Some tricks that can help you! πŸ˜„
            Joint Push Pull by Fredo6 for have thickness of one surface(s) (press TAB for have Options)
            Axes tools for that components are middle inside the form!
            Components onto faces by Chris Fullmer
            PS Boolean in Pro version is that! πŸ˜‰
