    Push-Pull trouble in SketchUp
    3 Posts 2 Posters 393 Views 2 Watching
    • R
      rstimler
      Having trouble using push pull tool on this drawing. Everything went well while making this drawing, but suddenly I can't use the push pull tool on anything. Even if I create a new shape, and carefully stay on axis, it doesn't turn grey, and will not respond to the tool. Shapes within the drawing, which I was able to edit before, are now un-editable. I suspect I've somehow wandered off the main axis (is that possible?). What am I doing wrong?
      Karen's bed.skp
      • BoxB
        You've set it to wireframe. So there are no surfaces to push.
        Go, View/Face style/ and choose anything other than wire frame.
        • R
          rstimler
          Thanks, Box. Knew it was something simple. Didn't see anywhere in tutorials, etc. that wireframe would keep the tool from working. One of those "Duh" moments.
