    Change paper size defaults in print menu?
    layout
    7 Posts 3 Posters 2.8k Views 3 Watching
    • davidmreinboldD
      davidmreinbold
      Hi there...
      On program start up Layout keeps re-setting the default paper size in the print menu back to A4, I hardly ever print on A4 paper at all...so this is very unpleasant! Is there a way to set A3 as the default paper size?
      Regards
      David
      • KrisidiousK
        Krisidious
        I'm having the same issue.... I think you have to set the default paper size for the system.
        By: Kristoff Rand
        • davidmreinboldD
          davidmreinbold
          how do you set the default paper size for the system?
          • KrisidiousK
            Krisidious
            You go to your Printer Panel that shows all your printers and right click on the default printer and then go to Printing Preferences>Page Size>ARCH D
            By: Kristoff Rand
            • A
              ArCAD-UK
              You should be able to set A3 by either using:
              FILE>NEW, pick the paper template from the dialogue and at the bottom select "Always Use The Selected Template"
              or
              EDIT>PREFERENCE>STARTUP and enter the required template name and select use default.
              The Startup page gives you a number of template options as to how LO works when you start a new drawing.
              • davidmreinboldD
                davidmreinbold
                Hi ArCad-UK
                I tried the setting A3 templates for start up...
                On start up I also checked by going to: File > Document Setup > Paper - the paper size shows up as A3.
                But if I print it still prints in A4, unless I go to: File > Page setup and re-set it from default A4 to A3. Note: if I set it to A3, save the file and restart the program it will revert back to A4, and it starts all over again...very annoying.
                Any ideas?
                • A
                  ArCAD-UK
                  Ah I see. You have to go through FILE>PAGE SETUP this happens a lot in Windows where software doesn't retain the paper size and adjust the printer for you. I tend to favour the export to PDF option which gets around the problem in the paperless age but even Adobe Reader needs you to configure the paper if you want a hard copy.
