[Plugin] Plugin to profile/optimize code
5 Posts 4 Posters 2.5k Views 4 Watching
    dfwlarch
    This might be a duplicate effort, but I couldn't find anything beyond this thread:
    http://sketchucation.com/forums/viewtopic.php?f=180&t=25101
    So... here is a SketchUp plugin that does basic profiling of each function call. It is modified from the stock profiler.rb that came with Ruby 1.8.7 (see https://github.com/ruby/ruby/blob/ruby_1_8_7/lib/profiler.rb ). A good writeup of profiler.rb is found here: http://www.ibm.com/developerworks/opensource/tutorials/os-ruby2/section3.html
    Usage
    1. Add the following line
      require 'SU_Profiler/SU_Profiler.rb'
    2. Add this at the start of the block to profile
      SU_Profiler::start_profile
    3. At the end of the block to profile, add
      SU_Profiler::print_profile() # to print to ruby console
      or
      SU_Profiler::print_profile(filehandle) # to print to file
    Output
    The output will be something like this:
    % cumulative self self total
    time seconds seconds calls ms/call ms/call name
    29.07 1.87 1.87 48 39.02 39.02 Sketchup;;Drawingelement#material=
    15.49 2.87 1.00 2095 0.48 0.70 BM_SimpleSolarStudy.inShadow
    10.71 3.56 0.69 2066 0.33 5.67 Range#each
    9.20 4.15 0.59 1 593.00 593.00 UI.savepanel
    4.59 4.45 0.30 72 4.11 13.44 BM_SimpleSolarStudy;;SSS_sunData#calcSun
    3.91 4.70 0.25 2376 0.11 0.18 Numeric#to_rad
    3.66 4.94 0.24 8952 0.03 0.03 Float#*
    2.42 5.09 0.16 4086 0.04 0.04 Float#/
    1.68 5.20 0.11 2145 0.05 0.05 Fixnum#&
    1.46 5.30 0.09 2095 0.04 0.04 Geom.intersect_line_plane
    1.44 5.39 0.09 48 1.94 4.23 BM_SimpleSolarStudy.getCentroid
    1.21 5.47 0.08 1668 0.05 0.05 String#==
    1.21 5.54 0.08 9854 0.01 0.01 Array#[]
    1.21 5.62 0.08 1 78.00 78.00 UI.inputbox
    1.20 5.70 0.08 2245 0.03 0.03 Hash#[]
    1.20 5.78 0.08 48 1.60 3.87 BM_SimpleSolarStudy.hsv2rgb
    0.98 5.84 0.06 192 0.33 0.57 BM_SimpleSolarStudy.remapVal
    0.96 5.90 0.06 2240 0.03 0.03 Kernel.nil?
    0.96 5.96 0.06 72 0.86 0.86 BM_SimpleSolarStudy;;SSS_sunData#calcJD
    0.95 6.02 0.06 2095 0.03 0.03 Sketchup;;Face#classify_point
    Latest version: 1.00, updated 2013-Aug-8
    [SU_Profiler.zip](/uploads/imported_attachments/24FQ_SU_Profiler.zip)
    Example usage:
    [profiler_test.rb](/uploads/imported_attachments/Q1CQ_profiler_test.rb)
      tt_su
      That is mighty interesting. Thanks for sharing.
        jolran
        It seams to be Printing to the console ok!
        Can't say I know how to profile properly, so this tool will be valuable for me. Thanks!
          driven
          cheers for this,
          did you test it with 'Developer Console' extension turned 'on', it seems to curry the returns
          john
            dfwlarch
            No, I didn't test it with the Developer Console. I was thinking the people who would most want to profile their code would have such a huge trace that they would want to dump to a file. Maybe printing to stdout should have an option of showing the top N entries...
