    [Plugin] Plugin to profile/optimize code
    5 Posts 4 Posters 2.8k Views 4 Watching
      dfwlarch
      This might be a duplicate effort, but I couldn't find anything beyond this thread:
      http://sketchucation.com/forums/viewtopic.php?f=180&t=25101
      So... here is a SketchUp plugin that does basic profiling of each function call. It is modified from the stock profiler.rb that came with Ruby 1.8.7 (see https://github.com/ruby/ruby/blob/ruby_1_8_7/lib/profiler.rb). A good writeup of profiler.rb is found here: http://www.ibm.com/developerworks/opensource/tutorials/os-ruby2/section3.html
      Usage
      1. Add the following line
        require 'SU_Profiler/SU_Profiler.rb'
      2. Add this at the start of the block to profile
        SU_Profiler::start_profile
      3. At the end of the block to profile, add
        SU_Profiler::print_profile() # to print to ruby console
        or
        SU_Profiler::print_profile(filehandle) # to print to file
      Output
      The output will be something like this:
      % cumulative self self total
      time seconds seconds calls ms/call ms/call name
      29.07 1.87 1.87 48 39.02 39.02 Sketchup;;Drawingelement#material=
      15.49 2.87 1.00 2095 0.48 0.70 BM_SimpleSolarStudy.inShadow
      10.71 3.56 0.69 2066 0.33 5.67 Range#each
      9.20 4.15 0.59 1 593.00 593.00 UI.savepanel
      4.59 4.45 0.30 72 4.11 13.44 BM_SimpleSolarStudy;;SSS_sunData#calcSun
      3.91 4.70 0.25 2376 0.11 0.18 Numeric#to_rad
      3.66 4.94 0.24 8952 0.03 0.03 Float#*
      2.42 5.09 0.16 4086 0.04 0.04 Float#/
      1.68 5.20 0.11 2145 0.05 0.05 Fixnum#&
      1.46 5.30 0.09 2095 0.04 0.04 Geom.intersect_line_plane
      1.44 5.39 0.09 48 1.94 4.23 BM_SimpleSolarStudy.getCentroid
      1.21 5.47 0.08 1668 0.05 0.05 String#==
      1.21 5.54 0.08 9854 0.01 0.01 Array#[]
      1.21 5.62 0.08 1 78.00 78.00 UI.inputbox
      1.20 5.70 0.08 2245 0.03 0.03 Hash#[]
      1.20 5.78 0.08 48 1.60 3.87 BM_SimpleSolarStudy.hsv2rgb
      0.98 5.84 0.06 192 0.33 0.57 BM_SimpleSolarStudy.remapVal
      0.96 5.90 0.06 2240 0.03 0.03 Kernel.nil?
      0.96 5.96 0.06 72 0.86 0.86 BM_SimpleSolarStudy;;SSS_sunData#calcJD
      0.95 6.02 0.06 2095 0.03 0.03 Sketchup;;Face#classify_point
      Latest version: 1.00, updated 2013-Aug-8
      [SU_Profiler.zip](/uploads/imported_attachments/24FQ_SU_Profiler.zip)
      Example usage:
      [profiler_test.rb](/uploads/imported_attachments/Q1CQ_profiler_test.rb)
      • tt_suT Offline
        tt_su
        That is mighty interesting. Thanks for sharing.
        • jolranJ Offline
          jolran
          It seams to be Printing to the console ok!
          Can't say I know how to profile properly, so this tool will be valuable for me. Thanks!
            driven
            cheers for this,
            did you test it with 'Developer Console' extension turned 'on', it seems to curry the returns
              dfwlarch
              No, I didn't test it with the Developer Console. I was thinking the people who would most want to profile their code would have such a huge trace that they would want to dump to a file. Maybe printing to stdout should have an option of showing the top N entries...
