    Module variables and nested class
    11 Posts 5 Posters 851 Views 5 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      Hi guys !
      As I said before on the forum, I'm new to ruby. I learned a lot, but despite a decent amount of research, I can't seem to figure this out :
      require 'sketchup.rb'
      module JBB_MyModule
      	@model = Sketchup.active_model
      	@layers = @model.layers
      	@customVar = #something
      	# Some code using these @variables
      	class JBB_LP_AppObserver < Sketchup;;AppObserver
      		def onNewModel(newModel)  #or onOpenModel
      			@model = newModel
      			@layers = newModel.layers
      			@customVar = #some other thing
      		end#def
      	end#class
      end#module
      It's not working. I tried local and class variables, which don't work either. It works with global variables, but obviously I'd like to avoid this. And of course it works using "Sketchup.active_model" each time, but the code becomes messy and unreadable.
      What should I do ?
      Thanks, jbb
      • renderizaR Offline
        renderiza
        Maybe try something like this...
        module JBB_MyModule
              @@model = Sketchup.active_model
              @@layers = @@model.layers
              @@customVar = #something
                 @@model = newModel
                 @@layers = newModel.layers
                 @@customVar = #some other thing
              end#def
              # Modify #
              if !file_loaded?(__FILE__) #then
                 @@jpp_test = UI.menu("Plugins").add_submenu("TEST")
                 @@jpp_test.add_item('Test') {
                    Sketchup.active_model.select_tool JBB_MyModule;;JBB_LP_AppObserver.new
                 # Add toolbars
                 jpp_test_tb = UI;;Toolbar.new "Test"
                 jpp_test_cmd = UI;;Command.new("Test") {
                 # icons toolbar
                 jpp_test_cmd.small_icon = "img/jpp_test_1_16.png"
                 jpp_test_cmd.large_icon = "img/jpp_test_1_24.png"
                 jpp_test_cmd.tooltip = "Test"
                 jpp_test_cmd.status_bar_text = "Test"
                 jpp_test_cmd.menu_text = "Test"
                 jpp_test_tb = jpp_test_tb.add_item jpp_test_cmd
                 jpp_test_tb.show
           end#class
        end#module
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          Aerilius
          You can use constants for this: Constants are looked up through all parent classes/modules until the first matching is found.
          module JBB_MyModule
              self;;MODEL = Sketchup.active_model
              # self;; makes sure the constant is defined in this module
              # Otherwise we would modify a "global" MODEL constant if someone had defined one.
                      MODEL = newModel  # or JBB_MyModule;;MODEL
                  end#def
              end#class
          end#module
            jiminy-billy-bob
            Thanks guys !
            I used constants as Aerilius pointed, but had to use .const_set() for this method to work.
            πŸ˜„
            • tt_suT Offline
              tt_su
              Use attr, attr_reader, attr_writer, attr_accessor to create methods to access the module/class's instance variables.
              The class << self syntax is needed for modules (class attributes). If you define instance attributes that is not needed.
              <span class="syntaxdefault"><br /></span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'sketchup.rb'<br /><br /></span><span class="syntaxdefault">module&nbsp;JBB_MyModule<br /><br />&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">layers&nbsp;</span><span class="syntaxkeyword">=&nbsp;@</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">layers<br />&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">@</span><span class="syntaxdefault">customVar&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxcomment">#something<br /><br />&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">class&nbsp;<<&nbsp;</span><span class="syntaxdefault">self<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;attr_accessor&nbsp;</span><span class="syntaxkeyword">;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">,&nbsp;;</span><span class="syntaxdefault">layer</span><span class="syntaxkeyword">,&nbsp;;</span><span class="syntaxdefault">customVar<br />&nbsp;&nbsp;&nbsp;end<br /><br />&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Some&nbsp;code&nbsp;using&nbsp;these&nbsp;@variables<br /><br />&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">class&nbsp;</span><span class="syntaxdefault">JBB_LP_AppObserver&nbsp;</span><span class="syntaxkeyword"><&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">AppObserver<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;def&nbsp;onNewModel</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">newModel</span><span class="syntaxkeyword">)&nbsp;&nbsp;</span><span class="syntaxcomment">#or&nbsp;onOpenModel<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">JBB_MyModule</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">newModel<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;JBB_MyModule</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">layers&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">newModel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">layers<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;JBB_MyModule</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">customVar&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxcomment">#some&nbsp;other&nbsp;thing<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end</span><span class="syntaxcomment">#def<br /><br />&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end</span><span class="syntaxcomment">#class<br /><br /></span><span class="syntaxdefault">end</span><span class="syntaxcomment">#module<br />&nbsp;</span><span class="syntaxdefault"></span>
              • tt_suT Offline
                tt_su
                Alternatively, in the case of observers, I usually define methods in the root module which I call from the observers - defining minimum amount of code in the observer class itself.
                  jiminy-billy-bob
                  Thanks a lot Thomas ! That was exactly what I was looking for.
                  For what ? Less bugsplats/erros ?
                  • tt_suT Offline
                    tt_su
                    Just because observers doesn't have access to the instance variables of the parent module. All I need observers for are tell when when things change - so I prefer to keep the logic that modifies stuff in the parent module along with the rest of it. It's an organization thing.
                      Anton_S
                      Is there any advantages or disadvantages of instance variables over the class variables in the module?
                      I know a few advantages for using instance vars:
                      1. no extra @ symbol
                      2. attr_... functions that give simpler organizations
                      I just wanted to know if there is any difference when it comes to using them in the module context.
                      • tt_suT Offline
                        tt_su
                        I don't think class variables in modules has any use.
                        In general people (when you search the net for Ruby) will advice against class variables if you can avoid them due to that they are troublesome when you create subclasses.
                          Anton_S
                          Thank you ThomThom πŸ‘
                          Moving to instance variables πŸ‘Ώ
