    Move Roof to Top in Dynamic Components
    3 Posts 2 Posters 1.2k Views 2 Watching
    • R
      ryangarnett
      Hi All,
      I am looking to build a building that allows a user to scale the building, specifically in the Z axis, which will move the roof component to the top of the copied floor components. I have the floor as a component, with the roof as a child component within the floor. I am getting close, but the roof floats above the floors when I scale the floor to add floors. I feel it is something really easy, assuming with the position Z, but I can't seem to figure it out.
      Any help would be appreciated.
      Thanks....
      Component Attributes
      Simple Building with Roof
      • P
        pcmoor
        try for Roof Z
        =if(FloorPart!Copies>0,int(FloorPart!Copies)*300,0)+300
        although copies reads 0, its actual value is different, ie 2000/3000-1 = -0.333333, not 0 as shown, therefore need to make integer and protect against negative
        also make sure of the position of the roof component axis (right click to place whilst edit) to achieve desired outcome
        cheers
        Philip
        • R
          ryangarnett
          Thank you Phillip, I will give that a try.
          Cheers,
          Ryan
