    Grass maxwell/ standalone ?
    extensions
    5 Posts 4 Posters 1.5k Views 4 Watching
      leki
      hi everybody.
      i have a problem with maxwell grass renderplugin. it doesn´t work? it is broken.
      it doesn´t render any grass.
      thax
      leki
      • BurkhardB Offline
        Burkhard
        Thanks for the info about Maxwell and the bunch of information about your problem, specs and versions. Helps a lot!
        http://www.ia-plus.de
          leki
          sketchup 8 pro
          maxwell standalone render
          i think, the problem is by the "Use Instances". how can i activate them. i can not find it in the export.
          • N Offline
            numerobis
            you can find it on the "output settings" tab
            http://support.nextlimit.com/download/attachments/5080537/su-sm-ui-output.jpg
            http://support.nextlimit.com/display/maxwelldocs/SketchUp+Output
            Maybe you have to press the little down-arrow key on top to activate the advanced mode (not sure if these are hidden in standart, i always use advanced).
            But normally turning instances on or of should make no difference for the grass. This only controls how the sketchup components and groups are treated on export. The grass will be generated automatically before the voxelisation and doesn't depend on these settings. You only have to disableinstances if you have a component with grass goups included or you will only get one of them generated:
            Grass is not currently inherited by instances in Maxwell, so keep that in mind: given multiple instances of a particular component, where that component contains groups with grass applied, grass will only be seen on the export for the definition, unless Use Instances is disabled.
            (http://support.nextlimit.com/display/maxwelldocs/SketchUp+Maxwell+Grass)
            • regnarR Offline
              regnar
              To get grass to show up in your renders, for the standalone plugin, you will need to start Maxwell Fire & go to Engine Settings and set Extensions to Enabled.
              Enable Grass to show up in render
              Windows 10 Professional 64 bit
              Intel I9 7900X Asus Prime X299-Delux
              EVGA GeForce RTX 3080 TI 12gb
              64 GB Ram Samsung 960 EVO Series 1TB PCIe NVMe M.2
