    How to Export a Point Cloud from a Sketchup model
    6 Posts 4 Posters 2.0k Views 4 Watching
    • B
      BluesDog
      Hi There!
      I was wondering, is there any way to export a SketchUp model as a point cloud?
      The closest I have came across by browsing the forums is a combination of the
      'Drape Cpoints' plugin over here (http://sketchucation.com/forums/viewtopic.php?t=21379) and the 'Export Cpoints to CSV' plugin over here (http://sketchucation.com/forums/viewtopic.php?p=354365#p354365).
      This approach is however undesirable because of the way 'Drape Cpoints' works. See attached picture.
      Any help would be much appreciated!
      Drape Cpoints (see image for limitations regarding use for generating a point cloud)
      • Didier BurD
        Didier Bur
        Try my PointsCloud plugin:
        http://rhin.crai.archi.fr/rld/plugin_details.php?id=678
        Regards,
        DB
        • B
          BluesDog
          Thanks Didier!
          I will check it out, and let you know how it goes πŸ˜ƒ
          • P
            pipinek
            @didier bur said:
            Regards,
            Alas, your plugin does not work with Su 2016, some break error while opening SU.
            Should it be other solution to export skp model as a point cloud, or a new version of your plugin?
            I would be most obliged for your reply and any piece of advice,
            Regards with many thanks
              @pipinek said:
              @didier bur said:
              Regards,
              Maybe try this: http://sketchucation.com/pluginstore?pln=Cloud
              • P
                pipinek
                Thank you very much, I will certainly give a try.
                Best regards and Happy New Year coming yearly.
