    Modeling Issue :(
    4 Posts 4 Posters 695 Views 4 Watching
    • B
      bpjmarriott1993
      Apologies, my brain isn't working well today. I think its the heat. >_<
      The problem is pretty obvious when looking at the picture, but the skirting board isn't meeting the floor.
      http://fc04.deviantart.net/fs71/i/2013/195/d/1/stairs_issue_by_bpjmarriott-d6deqfd.png
      I thought about extruding the base of the board to bring it down to where I want it to go but then its too wide and looks strange compared to the skirting boards on a flat level.
      I also can't change the stairs because I have them at the dimensions I need.
      Whats wrong?! 😞
      • D
        d12dozr
        In real life, the skirt board is usually wider than the base by necessity. If you have trouble visualizing it, why not google some images of stair skirting?
        http://goo.gl/f7ooYh
        • DavidBoulderD
          DavidBoulder
          Move the top angle in the board one tread width to the left and it should match the angle of the stair
          David Goldwasser
          OpenStudio Developer
          • beginnerB
            beginner
            Hi bpjmarriott1993,
            Small adjustment to the board is required.
            You have to add some unified triangles to finish off.
            See attachment. πŸ˜‰
            20130715-SUF-BeginnerStairs.skp
            Regards, SU 'beginner'
