    Visibility in Group/Component editing
    7 Posts 3 Posters 643 Views 3 Watching
      tomasz
      I have two tools that are using model.raytest(ray) and have bumped into a problem with DrawingElement visibility in Group/Component editing mode.
      All DrawingElement methods dealing with visibility - visible? and hidden? they refer to a state of the element in a model, but are completely unaware of a visibility of the element on a screen (OpenGL 3D space to be "precise").
      Group/Component editing options allow to Hide elements from a view, but how can we check it from Ruby?! Is there a way to figure out whether such an entity is really "visible on a screen".
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
        tomasz
        I have found Model.active_path from SU 7.0+. It looks I will have to compare an oldest entity in a family I get from the raytest with oldest entity from the active_path...
        Are there users still using SU6? πŸ˜„
        • jolranJ Offline
          jolran
          The only one I could think of is Pilou πŸ˜‰
            Use the second item in the returned array, with is the instance path array. Traverse through this and check if any of these entities are hidden on on a hidden layer. Works in all versions of SU.
              tomasz
              Thomas, it is not what I have been looking for. I know that this works, but I doesn't give you an info on whether an object is hidden by 'Group/Component editing' option from the 'Window/Model Info/Components'.
              The Model.active_path solution works very well. I have to obviously traverse whole active_path and compare each element with the second element of rayrest return.
                tomasz
                πŸ˜„
                  Ah, ok now I understand. Yes, then Model.active_path is what you need. And checking if Hide Rest of Model or Hide Similar Components is enabled.
