Ruby Console WWX Exception on startup
Hoping someone can help me with this. On launching SU, the ruby console pops up this warning:
WWX Exception: undefined method[]' for SketchupExtension::Array:Class
(eval):3119: warning: parenthesize argument(s) for future version
(eval):3142: warning: parenthesize argument(s) for future version`Anyone know which PlugIn is at fault?
What can/should I do to correct the issue? (short of disabling each extension one-at-a-time, and relaunching to ID the offending plug-in)So far I have just dismissed the warning, and continued working as per usual -- here doesn't seem to be any additional unstability (so far).
WWX is the WudWorx suite of tools:
I'm not sure which one is causing the error. You might contact them directly though.
Chris
Thanks for the quick reply Chris.
I just tried disabling and reloading the plugin (BoardMaker v1.0) and it appears to have cleaned up the issue.
Strange. I've been using the Wudworx tools since before its release and I've never seen that error. I wonder what caused it.
Register LoginAdvertisement
