    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    [Plugin]T2H_Stretch_By_Area v1.2.3(Aug 25,2013)
    30 Posts 21 Posters 50.4k Views 21 Watching
      tak2hata
      Hi,everyone.
      I update this version to 1.2.3 in Aug25,2013.
      Bugfix abot selecting vertices in curve.
      by TAK2HATA
        rv1974
        Tak2hata, thank you for refinements!
        Somehow you tool manage to temporarily 'disable' the skp file hierarchy (you know all those group\components relationships) and work on the primitive vertex level. Have you thought about some kind of 'tak2hata line tool' that would draw directly on the faces (and splitting them of course) regardless the hierarchy?
        • P Offline
          pgarmyn
          Extremely usefull โ—
          Thanks Tak2hata โ—
          • kimi kimiK Offline
            kimi kimi
            Man, if I knew this existed... ;( This is so awesome. I had to change the height of some building once, stretch all the windows, doors, with this thing I just cross it all, move it up and it's done. Previously, I had to open each window, each door, each column, each wall, ohhh maaan... It was such a frustration. Thank you!
              ronhiatt
              Thank you VERY MUCH for making this tool. I would pay good money for this. I am only buying Sketchup Pro because of this tool.
              How can I make sure I don't loose it? I'm worried Sketchup might mess it up.
              Thanks,
              Ron
                benpaq
                This is a very useful plug-in. I did not have any problem until I tried to use component attributes. The problem is not for the stretch by plug-in but what comes after it.
                For my component, I added an attribute "DoorSide" with value Left/Right. I would like to choose which group to display depending on DoorSide value. So I use hidden attribute for the group based on DoorSide value. Once the function is defined in hidden parameter, I can do a stretch by for an area of my component and it works fine. But when I change the value inside component option (Left/Right), the stretch is done another time! Do you have any idea what is happening? It looks like the ruby code is executed again.
                Thank you,
                Benoit Paquette
                  ronhiatt
                  Hi, I clicked on the "Donate" Button next to "Stretch by Area", but it doesn't work.
                  Stretch by Area is a VERY important tool for me. I don't know if Sketchup would work for me without it. I would like to donate $50 to you. I also would be very happy if you would improve "Stretch by Area" if you have time.
                  Thanks,
                  Ron
                  • P Offline
                    petersaal
                    Thank you for sharing this plugin. Super helpful.
                      bsfranza
                      wow ๐Ÿ˜„
                      i dont know how it could happen to me just NOT to know and use this FREAKING AWESOME plugin ๐Ÿ˜„
                      damn... sometimes stuff is slipping by...
                      super product, but allow me to make a humble request or wish for making it even more better ๐Ÿ˜„ ->
                      give the user the option to "complete" selection with shift strg modifications just like with regular su activation tool... that helps to only select whats really of interest!
                      would be cool if the t2h could implement this in a convinient way like a two step process 1. selecting the verts with the help of the modifier keys and then 2. right click to finish selection and start moving ๐Ÿ˜„
                      thanks for this awesome plugin!!! thumbs up
                        andsgf
                        ะกะฟะฐัะธะฑะพ
                        • 2 / 2
