    Flipping Crazy
    59 Posts 8 Posters 6.1k Views 8 Watching
    • bsintzelB
      bsintzel
      Pilou,
      Since you put a lot of extra effort into this problem, I'm going to as well. First however, I have to be certain nothing is getting misunderstood by either of us.
      I'll begin by asking you to use the BoltMaker XII plugin and (using the model I provided), try the following steps:
      1 - open the file I've attached. It contains: a component (a block) with a bolt in it created using BoltMaker XII and a 'Source' component made by me.
      2 - From the Window/Entity Info dialog box, confirm that the 'Source' bolt I created is a component. Double-click on the 'Source' component, you'll see that it's z-axis is pointing up (standard convention).
      3 - From the Window/Entity Info dialog box, confirm that the bolt created by BoltMaker XII is a component. Double-click it and examine its axis. You'll find that the z-axis is pointing down. This is not standard practice as a new component should have the z-axis pointing up.
      4 - Now run SDMitch's ComponentReplacement plugin against the 'Source' and 'Target' components.
      What you should see is that the 'Source' component replaces the 'Target' component at a location and orientation you wouldn't expect.
      Try this and let me know what you find. If you have a procedure I can follow that results in a properly oriented target replacement ( using the model I provided) ...I'll be ecstatic 😍 .
      Warm regards
      Bob
      Bob
      SU8 format
      SU2013 format
      I've taken obfuscating to a whole new level!
      • bsintzelB
        bsintzel
        Guys,
        FINALLY...after listening to all of your ideas, I derived a solution based largely on your comments and it worked perfectly. When it happened, it was one of those cathartic moments.
        The solution was mainly to forget all about trying to 'replace' a BoltMaker XII bolt with mine and instead, figure out how to 'insert' my custom bolt exactly where I wanted it in another component.
        Steps followed:
        1 - Selected my custom bolt component (the source).
        2 - Using ThomThom's Axis tool, set the insertion point of the custom bolt x-y-z axis to 'center'
        3 - Selected the Box component (the Target).
        4 - Using ThomThoms Guide Tools plugin, set the Target's bounding box's cPoint at bound center.
        5 - Click on the 'Source' component then CTRL-click on the 'Target' component.
        6 - Using ThomThom's Guide Tools plugin, select Insert Component at cPoints.
        voila, the custom bolt is inserted in the block at the precise location I want. 😍
        THANK YOU ALL for your input
        Figure 1: Set the custom bolt x-y-z axis to 'center'
        Figure 2: Set cPoint of 'target'
        Figure 3: Insert 'source' component at cPoint of 'Target' component
          It appears you've got a process you're happy with. That's cool. πŸ‘
            So you don't use a replacement mehod πŸ˜„
            Yes ...but how do you make when you have a little hundred of bolts in any orientation to change ? πŸ˜„
            PS For me its' save as V6 or V7 for read the files πŸ˜‰
            • bsintzelB
              bsintzel
              Hi Dave...
              Forgive me if I already asked you, but could you remind me of the 'fewer' steps you use πŸ˜„ .
              I've had so much correspondence around this topic with so many people on different forums, I've lost track 😳
              Bob
              • bsintzelB
                bsintzel
                Piloe,
                Re "So you don't use a replacement method". Sorry to say, but I was going about this all wrong. I was using BoltMaker as a way to automatically create a bolt that would resize itself according to the dimensions of the target. I thought that by simply replacing the BoltMaker bolt with mine that it would be very easy to do. Sadly, I was wrong.
                I do thank you for your efforts.
                Bob
                  Bob, there are links on the first page of this thread. No plugins required the way I do it.
                  I'm curious about your procedure. You are locating the bolt so its center is aligned with the center of the block component. Why do you put a fastener in a single piece? Wouldn't that fastener be used to hold two parts together? And if that's the case, you don't want the center of the bolt located at the center of a single part, do you? What happens when you have a pair of bolts to locate on the part. Both of them can't be at the center in the part.
                  I would locate the insertion point for the screw in your example centered at the top of the head and place the screws at points on the surface of the part. These would be the points you'd identify in reality instead of points inside the part.
                  And with gluing, the bolts drop in easily in any orientation desired.
                  The only plugin used in the creation of the model in the video was to drill and counterbore the holes for the bolts. Everything else was done with native tools. It would be trivial to adjust the lengths of the bolts as needed so I didn't show that.
                    Maybe you can also look at Component Dropper by ThomThom πŸ˜‰
                    • bsintzelB
                      bsintzel
                      Hi Dave...
                      This is an excellent video tutorial. Thank you so much πŸ‘ πŸ‘ . I would prefer your solution to mine if I can get it to work on BoltMaker XII output. You see, BoltMaker automaticaaly sizes the bolt to match its target.
                      Just one question: was the bolt you used created with BoltMaker XII and if so, did you manipulate it's axis in any prior to gluing them?
                      To answer your question "Why do you put a fastener in a single piece?".
                      Answer: To illustrate the 'flipping' issue I was experiencing when using BoltMaker XII. I totally agree that a single bolt in just one piece would serve no purpose πŸ€“ .
                        @bsintzel said:
                        Hi Dave...
                        Ah. Thank you. I'm glad that was helpful.
                        No. I didn't use any plugins to create the bolt. I just drew it manually. In this example I made the screw, washers and nut as separate components and made a nested component of them. When I made the nested component I set Gluing to 'Any' and clicked on the button to set the axes. I then placed the axes at the top of and centered on the head. It took little time to do the whole thing. I think I spent more time looking up the real dimensions for the head and socket than drawing the components. BUT I don't ever have to look that info up again.
                        Since the screw, washers and nut are separate components, I can easily get a parts list from the model if I want it.
                        That makes sense. It seems to me that the boltmaker plugin currently creates more problems than it solves and forces you to be inefficient as you are working.
                        I now have a 1/4 in. socket head cap screw that is designed to sit with the top of the head flush to the surface of the part. It would be easy enough to edit its length or modify the location of the insertion point so I can have it insert with the washer on the surface. I could eliminate the washers or change the nut to a locking nut or whatever and do it all with only the native tools.
                        • bsintzelB
                          bsintzel
                          Dave R,
                          I 'really' liked the plugin you used to counter-bore. I design folding furniture that I ultimately make for myself so the counter-bore plugin you used would be a real time saver.
                          I found a suite of woodworking plugins https://sites.google.com/site/wudworx/plugins-and-tools/wwxboardmaker) and purchased the Wudworx Library Version 2(includes BoardMaker Pro, Dovetails, M&T, and Drill plugins).
                          I'm not sure if it's the same plugins you use. If so, you should get a kickback for semi-advertising their plugin πŸ’š
                          I can't thank you enough for the amazing support you've provided.
                          Warm regards
                          Bob
                            Bob, that's the plugin I used for the holes. I don't suppose you have much need for dovetails on your folding furniture but the Wudworx Dovetail plugin is perfect as is the M&T plugin.
                            I'm glad if something there was helpful.
                            • bsintzelB
                              bsintzel
                              Dave R,
                              Dovetails on folding furniture? lol...your right about that. Actually, I'm about to purchase a dovetail jig to add to my shop so the dovetail plugin is a perfect complement to it.
                              Bob
                                What dovetail jig do you have your eye on?
                                • bsintzelB
                                  bsintzel
                                  Dave R.,
                                  No particular product as yet.
                                  When it comes to woodworking tools, I'm pretty serious and somewhat picky about what I buy.
                                  However, I've only begun my research into dovetail jigs. I have no 'hands-on' experience with them so I'm taking the time to learn as much as I can before buying anything.
                                  We have a couple of places here that I like to shop at (Lee Valley and Busy Bee). They employ experienced craftsmen that actually use the tools they sell. Better yet, they offer free seminars to prospective purchasers. Can't beat that πŸ‘
                                  Have you had different experiences with dovetail jigs yourself? If so, any tips about what constitutes a good dovetail jig would be welcomed.
                                  Bob
                                    I'll send you a PM. We've already dragged this thread off topic. πŸ˜‰
                                      Seems cool tool! β˜€
                                      No glue is necessary ?
                                      Cool this one πŸ˜„
                                        Pilou, you might be able to get away without using glue but normally a dovetail joint is glued. The joint is from the days when glue wasn't especially strong, though and it makes a great corner joint. These days, even the most common glues are stronger than the wood. From a practical standpoint there are easier joints to make and for simply joining two pieces of wood, a dovetail joint isn't a requirement for a strong joint. Dovetails can be elegant if made correctly or they can be ugly. There's no point in making dovetail joints if they are going to be fat and ugly. πŸ˜‰
                                          Thx, amazing wood's world! β˜€
                                          • 3 / 3
