    Maxwell render RS for SketchUP
    extensions
    3 Posts 3 Posters 904 Views 3 Watching
    • I
      imPEREZ
      Hello, I have a problem (img)
      does not fall down, also in Fire. πŸ˜•
      What to do?
      • N
        numerobis
        maybe reinstall Silverlight or try the new plugin without silverlight.
        if that doesn't help you should contact JDHill... πŸ˜‰
        edit:
        now i see that you're using SU 2013 which isn't officially supported yet, but accourding to JD it should work (the lastest version)
        • regnarR
          regnar
          Ran into the same issue after installing, tried going back to a earlier version of Silverlight but to no avail.
          But now there is a update to Maxwell Render, appears they have moved away from Silverlight & now supports Sketchup 2013.
          Here is the link to the Maxwell's website
          http://www.maxwellrender.com/forum/viewtopic.php?f=107&t=40712&sid=5e2cd8d5040be25d6c31bb6f68b92c4d πŸ˜„
          Windows 10 Professional 64 bit
          Intel I9 7900X Asus Prime X299-Delux
          EVGA GeForce RTX 3080 TI 12gb
          64 GB Ram Samsung 960 EVO Series 1TB PCIe NVMe M.2
